Ansys Products
Ansys Products
Ansys 2024 R1 – The installation completed with warnings/errors.
    • akshaysoma009
      I tried installing Ansys 2024 R1 on my laptop, I previously had 2022 R1 student so I uninstalled it and ran the 2024 setup file as admin. It installed with errors. I uninstalled and deleted the installer and all folders that were created during the installation. Also deleted the folders in %APPDATA%\Ansys and re downloaded and re installed the 2024 R1 and still face the same error. I am copying error log below. Please help.
      Ansys installation: Sat Feb 17 11:12:31 2024
      Revision: 2024 R1
         ###### Error #######
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigDiscoUnified.tcl'
         'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Process failed to start: Access is denied.
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCommonDiscovery.tcl'
             Process failed to start: The system cannot find the file specified.
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigADR.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCommon.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigHelp.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigWB.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigRSM.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigSpaceClaimUnified.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCFX.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCHEMKIN.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigEnSight.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigFENSAP.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCFDPost.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigFLUENT.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigPolyflow.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigFORTE.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigRDWorkbench.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigTG.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigSpeos.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigSpeosLabs.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigAQWA.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigACP.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigANSYS.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigMotion.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigClientLicensing.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigAVIEW.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigOptiSLang.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigCAD.tcl'
         Exit Code: 0
         Error executing configuration script 'C:\Users\aksha\AppData\Local\Temp\ans_install_tmp12504\config\AnsConfigSpeosCads.tcl'
         Exit Code: 0
    • Rajeshwari Jadhav
      Hi Akshay,
      I think you need to uninstall 2024R1:- Image_2024-01-18_11-19-52.png from the 2024R1 program group
      Then check your graphics card has the latest driver available for it by going to the Nvidia website (Official Drivers | NVIDIA)
      Re download the installation media,in case it got corrupted or a partial download.
      Uncompress the install files
      Then, with an account with admin rights, right click on setup.exe and select 'Run as Administrator' as this issue could be a permissions problem during the install and this step will help.
  • The topic ‘Ansys 2024 R1 – The installation completed with warnings/errors.’ is closed to new replies.
