Ansys Free Student Software
ANSYS 2021R1 Workbench Not Opening
    • ASchroder
      Hello, nI am trying to run a model in ANSYS2021 R1 and my workbench refuses to open properly. The program loads and then as soon as it is finished loading, the Workbench disappears off the screen and shows nothing. I tried updating my graphics driver as found in another discussion post, and nothing. I can open other parts of ANSYS like SpaceClaim but not Workbench. Any help is appreciated. nThanksn
    • George Karnos
      Hello ASchroder,
      If Workbench Shows in the Windows Taskbar as running:
      Can You try the following:
      Method 1
      Start the program.
      Right-click the program on the taskbar, and then click Maximize.
      Right-click a blank area of the taskbar, and then click Cascade Windows.
      Resize the program's window as appropriate.
      Method 2
      Start the program.
      Right-click the program on the taskbar, and then click Move.
      Move the mouse pointer to the middle of the screen.
      Use the ARROW keys on the keyboard to move the program window to a viewable area on the screen.
      Press ENTER.
      Resize the window if necessary.
      If that does not help, make sure workbench is not running, then:
      Using Windows File Explorer, go to:
      %APPDATA%Ansys
      You should see a directory V2## corresponding to the version you installed.
      Rename that directory to v2##.old
      Now Retry starting Workbench.
      Please let me know if this Helps!
      Best,
      Geo
    • jankowskimd
      I have the same issue. None of those fixed or addressed it, nor anything I've seen on a half-dozen other threads here and elsewhere. I've done uninstalls and re-installs. I've run everything as administrator. I've turned-off firewalls and virus software and set firewalls to allow Workbench to have free reign. I've renamed the roaming app folder from 211 to 211_old. I have a NVIDIA Quadro T1000 and used the NVIDIA control panel to assign "high-performance NVIDIA processor" to all ANSYS software.
      Every other piece of Ansys software seems to load besides Workbench. It runs as if it is starting, then gets to stating, "Initializing project..." and then after several seconds, it disappears. Similarly, Workbench shows as running in task manager, then disappears. No error messages are generated.
    • jankowskimd
      Nevermind. Looks like I have a "Sentinel One Agent" blocking the application based on the Windows Event Log.
    • emanuelberil
      Hello geo karnos, I had the same problem as our colleague who opened the topic. I managed to solve it with your tips, I had already uninstalled the program and updated all the drivers of the computer ... Thank you very much, you helped me a lot. Just click on maximize.
    • kinnamje
      Just curious, how were you able to resolve this? I've been trying to hunt down S1 exclusion list for ANSYS and no dice so far. This is exactly the issue I'm seeing with my client and trying to figure out what adjustments need to be made.
    • NURFATHIN
      My workbench ANSYS2021 R2 refuses to open properly. The program loads and then shows 'initializing Licensing', the Workbench disappears off the screen and shows nothing. I can open other parts of ANSYS like SpaceClaim but not Workbench. I try to uninstall and install back. I don't know where the problem is. Any help is appreciated.
      Thanks
    • George Karnos
      Exit all Ansys Programs.
      Try renaming the %Appdata%Ansys to %Appdata%Ansys.old
      Now, try to run Workbench.
    • pliebersbach
      jankowskimd kinnamje my company also uses the sentinel one antivirus client and some coworkers have issues with it blocking their workbench applications. our company IT is understaffed and has not had too much time to resolve the issue. where either of you able to resolve the issues yourselves and could you advise on what the solution is to sentinel one blocking some ansys executables? any help would be greatly appreciated.
    • jjdai
      Sorry to quote but has anyone of you figured out the issue? I tried every tricks above but still couldn't run Workbench even after IT involved. Btw we are using SentinelOne too. Any input would be appreciated!
    • benjamin_launcher
      Your SentinelOne admin needs to create an Interoperability Exclusion to allow Workbench to run. Point your admin to this SentinelOne Knowledge Base article to do so: https://support.sentinelone.com/hc/en-us/articles/360002679893-Interoperability-Exclusions They will need to allow list the location where Workbench is installed on your computer. This cannot be done from your computer. It needs to be done in the SentinelOne console.
Viewing 10 reply threads
  • The topic ‘ANSYS 2021R1 Workbench Not Opening’ is closed to new replies.
