TAGGED: harmonic, piezo-energy-harvesting, piezoelectric, resistor
June 10, 2021 at 5:48 pm
bugrrasen
Subscriberhow can i add resistance between 2 piezoelectric layers for piezoelectric analysis in workbench ?
June 21, 2021 at 4:51 am1shan
Ansys EmployeeYou can add a CIRCU94 circuit element with KEYOPT(1) = 0. Have a look at section 4.4 of https://webthesis.biblio.polito.it/12162/1/tesi.pdf for the command snippet.
Regards Ishan.
May 5, 2022 at 10:01 amImanFakhari
SubscriberHi @1shan
Thank you
but I am not able to follow your work.
How do I add a resistor (for example 100 ohms) between the top and bottom layers of a piezoelectric beam on the Ansys Workbench?
please explain more
May 5, 2022 at 10:31 amerik.kostson
Ansys EmployeeHi - as indicated follow those links and one would need to add command snippets for ciruc94 elements - search on the internet and here in the forum for more info.
Erik
Viewing 3 reply threads- The topic ‘Ansys 2021 Workbench Piezoelectric Analysis- Add Resistor’ is closed to new replies.
