July 11, 2020 at 10:38 am
RiddhishKathar
SubscriberI am trying to solve this 2D static structural problem from 2 weeks. The meshing is good and inputs are also sufficient for the geometry to get solved. But I don't know why, this error i constantly appearing "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes"
I also tried to turn off distribute solution from the solver process settings but to my regret, the error still persists. I also have a lot of disc space free and I also tried to reinstall the software 2 times.Â
I am attaching the screenshot of the error message and solution information.Â
I am currently running out of time as my technical round for an interview will be happening within these 2 weeks so please help me to solve this error.
Thank You!!
Here is the solution information:
*** IMPORTANT LICENSING MESSAGE ***
ANSYS LICENSE MANAGER ERROR:
Failover feature 'ANSYS Mechanical Enterprise' specified in license preferences is not available.
Request name ansys does not exist in the licensing pool.
No such feature exists.
Feature: ansys
License path: C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic;
FlexNet Licensing error:-5,357
*** ERROR - ANSYS license not available.
D I S T R I B U T E D A N S Y S S T A T I S T I C S
Release: 2020 R1 Build: 20.1 Update: UP20191203 Platform: WINDOWS x64
Date Run: 07/11/2020 Time: 15:40 Process ID: 7528
Operating System: Windows 10 (Build: 18362)
Processor Model: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Compiler: Intel(R) FORTRAN Compiler Version 19.0.0 (Build: 20190206)
Intel(R) C/C++ Compiler Version 19.0.0 (Build: 20190206)
Intel(R) Math Kernel Library Version 2019.0.3 Product Build 20190125
Number of machines requested : 1
Total number of cores available : 4
Number of physical cores available : 2
Number of processes requested : 2
Number of threads per process requested : 1
Total number of cores requested : 2 (Distributed Memory Parallel)
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2018 Update 3 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Core Machine Name Working Directory
0 DESKTOP-RPRQN5M C:Usersriddhish katharDesktop_ProjectScratchScr2466
1 DESKTOP-RPRQN5M C:Usersriddhish katharDesktop_ProjectScratchScr2466
Total CPU time for main thread : 0.4 seconds
Total CPU time summed for all threads : 0.1 seconds
Elapsed time spent obtaining a license : 0.0 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.0 seconds
Elapsed time spent solution - preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Maximum total memory used : 4.0 MB
Maximum total memory allocated : 0.0 MB
Total physical memory available : 8 GB
Total amount of I/O written to disk : 0.0 GB
Total amount of I/O read from disk : 0.0 GB
E N D D I S T R I B U T E D A N S Y S S T A T I S T I C S
| DISTRIBUTED ANSYS RUN COMPLETED |
| Ansys 2020 R1 Build 20.1 UP20191203 WINDOWS x64 |
| Database Requested(-db) 0 MB Scratch Memory Requested 0 MB |
| Maximum Database Used 1 MB Maximum Scratch Memory Used 1 MB |
| CP Time (sec) = 0.078 Time = 15:40:27 |
| Elapsed Time (sec) = 1.000 Date = 07/11/2020 |
July 11, 2020 at 2:57 pm
peteroznewman
SubscriberThe installation of ANSYS on this computer is flawed. You need to uninstall ANSYS and follow the steps in posts about license errors to clean out your computer before you reinstall ANSYS.
- The topic ‘Ansys 2020 Solver Error’ is closed to new replies.
3597
1208
1092
1068
952
