January 11, 2018 at 5:16 pm
kgriffin13
SubscriberI have version 18.2 downloaded on my laptop and I'm having trouble adding a surface monitor, on older versions you double clicked "monitors" and the option to add a surface monitor came up in the "task page" but clicking on "monitors" in version 18.2 does not make anything come up in the "task page"
January 11, 2018 at 6:31 pm
January 13, 2018 at 4:21 pm
January 15, 2018 at 6:53 am
January 22, 2018 at 2:07 pm
buidinhanh
SubscriberThank u kgriffin13 and Mr. Vishal Ganore. I can't find some features of old version like File name and X axis in version 18.2. Please teach me.
January 24, 2018 at 11:49 am
January 24, 2018 at 1:23 pm
buidinhanh
Subscriberthank you, sir
May 20, 2019 at 4:25 pm
esha
Generate the report file using first step (in surface report definition, activate report file and report plot, make sure you add def file under selected report definition). Step 2 is to explore report plot.
Hi, I want to attach batch my fluent case to get drag and lift coefficient but in new version by this I can not put any path. and cluster does not create a local file. while using the feature of old version I do not need to give any path. If you have solution please let me know how may I get data for Cd and Cl from clutser?
- The topic ‘ANSYS 18.2 Fluent Surface Monitors’ is closed to new replies.
5844
