July 19, 2018 at 9:57 am
jcastello
SubscriberHello,
I'm new here.Â
After making a search on internet I haven't found anything similar to my problem.Â
I installed ANSYS AIM Student yesterday and for some reason, after installing the software with any issue, when I want to run the WorkBench 19.1 it says me this:Â Â
Link to the picture: https://drive.google.com/file/d/18CpgA3n7xRBS2xhh77Jk9ndi7gcMKDYN/view?usp=sharing
I've uninstall it, and reinstallit again but the same problem appeared again.Â
I was installing it on the D unit, should I do it on the C unit? I think that this doesn't matter but maybe it works.Â
Thank you. -
July 19, 2018 at 5:49 pm
tsiriaks
Ansys EmployeeHello jcastello ,
If your D drive is a physical/local drive, it is ok.
For this issue, please try installing the ANSYS Student package as well.Â
Please let me know if that makes any difference.
Thank you,
Win
July 19, 2018 at 9:11 pm
aydiincann
SubscriberI have the same problem.I can not run the program.
July 19, 2018 at 9:13 pm
aydiincann
SubscriberAn error occurred while processing your request.
Reference #30.6895c4d.1532034712.b41daff0
I will try again.
but now this error.
I tried the folder d.
but it did not work.
July 19, 2018 at 11:08 pm
tsiriaks
Ansys EmployeeHi aydiincann,
I have just tried downloading the ANSYS Student package and it worked for me.
If you experience the above error and if you are using Windows 10, this post might be helpful to you
https://windowsreport.com/error-occurred-while-processing-your-request-windows-10/
Thank you,
Win
July 19, 2018 at 11:17 pm
aydiincann
SubscriberNo ? dont use windows 10.Â
my schedule is not working.
https://drive.google.com/file/d/18CpgA3n7xRBS2xhh77Jk9ndi7gcMKDYN/view?usp=sharing  I have this mistake.
July 19, 2018 at 11:38 pm
tsiriaks
Ansys Employee Hi aydiincann,
Did you install ANSYS Student package ? Or did you just install the ANSYS AIM Student package like jcastello did ?
If you haven't installed ANSYS Student package, please try that and let me know if it helps.
If you have already installed it and still see this issue, try the suggestions from these two posts
/forum/forums/topic/workbench-18-2-fatal-error-framework-error/
and
/forum/forums/topic/fatal-error-showing-that-the-view-graphscene-has-not-been-registered-how-to-fix-it/
Thank you,
Win
July 20, 2018 at 9:36 am
aydiincann
SubscriberI install ANSYS Student.
Please solve my problem.
July 20, 2018 at 4:06 pm
tsiriaks
Have you tried all the suggestions provided in the two posts ?
and
Thanks,
Win
July 20, 2018 at 5:10 pm
JakeC
Ansys EmployeeThis could also be graphics card related.
Please update your graphics drivers to the latest version, and verify that the "good" card is enabled as the primary card.
For instance if you are using a laptop with an intel card and an nvidia card in it, open the nvidia control panel and 3d settings, and verify that "High Performance Graphics Processor" is selected as the primary card and not "auto detect"
Thank you,
Jake
July 20, 2018 at 7:07 pm
jcastello
Subscriber I've made this and continues to appear the problem.
Also I tried to install the Ansys Student package and the same.
I will try to do the what tsiriaks passed on the two links. -
July 22, 2018 at 6:06 pm
jcastello
SubscriberHello,Â
I've tried all the options you said before, but anything is making it to work.Â
I will try to install it on the C unit as a last option, but I dont feel like it will work.
Any other option?? -
July 22, 2018 at 9:36 pm
jcastello
SubscriberHi again,
I don't understand the difference between C and D, but it worked, now it opens.Â
I installed the Ansys Student on the C partition and works. -
July 23, 2018 at 6:17 pm
tsiriaks
Ansys EmployeeHi jcastello,Â
That's great news ! Thank you for letting us know.
I don't understand either. C and D shouldn't makes any difference if both of them are physical/local drives. I think it's something specific on your systems.
Win
July 30, 2018 at 11:59 pm
Lindsay
SubscriberI am having the same Ans.SceneGraphChart.SceneGraphAddin error that jcastello pictured above. I can't get anything from this post to resolve the issue. It's a little frustrating, as it was working just fine, so I don't know why it has started all of a sudden. Was there anything else that someone did that fixed this?
July 31, 2018 at 12:21 am
July 31, 2018 at 12:37 pm
JakeC
Ansys EmployeeHi Lindsay,
It may be worth resetting your preferences.
Close all open Ansys applications
Open Windows File Explorer and put the following in the path/address bar:
%APPDATA%ansys
Rename v1xx directory to v1xx_old (replace the xx with the version you are using)
Now open workbench again.
Thank you,
Jake -
August 1, 2018 at 11:12 am
August 1, 2018 at 12:22 pm
JakeC
Ansys EmployeeHi SK_Runek,
What have you tried from the suggestions provided in this thread?
Can you send a screen shot of what "Show Details" shows?
What graphics card do you have?
Thank you,
Jake -
August 1, 2018 at 12:46 pm
August 1, 2018 at 12:51 pm
user deleted
SubscriberI download Ansys from https://www.ansys.com/academic/free-student-products . That run setup.exe and finish installation. After this i try run Workbanch 19.1 but watch this error. May be i should do anything more?
August 1, 2018 at 12:58 pm
JakeC
Ansys EmployeeIf you run the Nvidia Control Panel and set the "High Performance Graphics Processor" specifically?
Which graphics card is still enabled?
Thank you,
Jake -
August 1, 2018 at 2:01 pm
user deleted
SubscriberYes, i set  High Performance Graphics Nvidia previously
I enabled again second card Intel(R) HD Graphics FamilyÂ
August 1, 2018 at 2:25 pm
JakeC
Ansys EmployeeThe GeForce line of graphics cards are not really workstation grade cards, and may not be able to run the Ansys Products.
If you run Start -> Type dxdiag.exe, can you send screenshots of each of the Display# tabs?
Thank you,
Jake -
August 1, 2018 at 2:57 pm
Lindsay
SubscriberThank you jcallery! I can now open previous projects and get the toolboxes to show up!
I still am getting the errors that SK_Runek and jcastello have pictured above if I try to just open up Workbench from scratch, but it looks like it is working if I just open a new project once an old project is opened.
I new to Ansys and don't really use Windows often, so I don't know (but assume) the other error message is Windows related? There was a suggestion above that mentions using https://windowsreport.com/error-occurred-while-processing-your-request-windows-10/, but that requires payment to a program that has a lot of reviews about getting scammed after using it - so I don't really feel comfortable going that route. And just wanted to give others a heads up about that as well.
Thank you for your help!!!! I'm so happy to be able to get back in and use ANSYS again!!!!
August 1, 2018 at 4:20 pm
JakeC
That is interesting, I haven't seen that issue before.
Can you try closing all open ansys applications and rename the following directory:
%APPDATA%Ansys
to
%APPDATA%Ansys_old
Then try launching workbench from the shortcut again.
You may also want to try running ProductConfig:
Start -> All Programs -> Ansys -> Utilities -> Right Click on Product and Cad Configuration -> Run As administrator
Then click on Configure Products and Cads and follow the prompts.
Thank you,
Jake
August 2, 2018 at 7:18 am
August 2, 2018 at 4:31 pm
tsiriaks
It seems the driver for your NVIDIA GeForce 920M is quite old (5/1/2017) .
Please refer to this Nvidia site
http://www.nvidia.com/Download/index.aspx?lang=en-us
fill out information and download and install the latest driver from there
Can you also try using ANSYS with just your notebook monitor ?
Thank you,
Win
August 2, 2018 at 4:44 pm
JakeC
Ansys EmployeeAdditionally, please check to see if there are any files that start with QT and end with .dll in the c:windowssystem32 directory.
If so, please rename or delete those, reboot, and try again.
Thank you,
Jake
August 28, 2018 at 8:36 pm
user deleted
Subscriber?????? SK_Runek
??????? ?????? ?????????Â
? ???? ????? ????????? ???????????? ??????? ?? ?? ??????.Â
?? ?????????? ???? ?????????? ?????????? Intel HD 530. ????????? ????????? ????????? ?????? ???????? - ?? ???????.
? ???? ??? ?????????? ?????? WB ??????? ??????? ??? ?????????? ?????? ?? ????. Â
/forum/forums/topic/error-with-workbench-scenegraphchart/
??????? - ???????? ??? ???????????? ?????????? ???????.Â
August 28, 2018 at 9:56 pm
tsiriaks
Ansys EmployeeHi Rais,
I used google translate and get this rough English translation of your post
Did you solve the problem?
I have the same error after installing the distribution.
The computer also built-in video card Intel HD 530. Installed the latest available driver version - did not help.
I do not have previous WB files, so I can not do as others suggest.
Decision:
In short - write down the user name in Latin letters.
I would recommend to try to create a new user profile (and computer name) that uses only English alphabets like the resolution from aliberati from the link that you posted. Then, see if this helps.
Thank you,
Win
August 29, 2018 at 6:18 am
user deleted
SubscriberHi tsiriaks!
I wrote down the computer user name in English and the problem was solved. The computer name was already in English.
Thank you.
August 29, 2018 at 4:44 pm
tsiriaks
Ansys Employee -
November 3, 2018 at 11:24 pm
frank2243
SubscriberDid anyone have ever found a solution for this problem?
I have Windows 10 installed on an iMac 5K with the latest AMD drivers.
November 9, 2018 at 10:26 am
fkcom
SubscriberHallo helpers,
ich have the same problem (see attached screenshots). Here is what I did already:
- updated graphic card drivers
- reinstalled ansys student package
- changed the system language to english
- renamed %APPDATA%Ansys to %APPDATA%Ansys_old
- in Product and Cad Configuration there is nothing to choose from
unfortunately nothing helped but I really need to get it run for my diploma thesis.. can anyone help me out?
thank you in advance.
felix
November 9, 2018 at 7:56 pm
tsiriaks
Ansys EmployeeHi fkcom,
Have you tried creating a new/simple Windows user account that only has English letters like abc or a123 ?
Thanks,
Win
November 19, 2018 at 5:52 pm
smlbykcc
Subscriber% APPDATA% ANSYSÂ Â bu dizini bulam?yorum.
November 19, 2018 at 6:48 pm
tsiriaks
Ansys EmployeeHi smlbykcc,
I used Google translate and it seems your issue is
"% APPDATA% ANSYSÂ Â I can't find this directory how to change it."
Did you have space when you look for this directory ?
It should be something likeÂ
C:Users
AppDataRoamingAnsys
If you need further help on this, please create a new thread, then reference this one.
Thank you,
Win
November 28, 2018 at 7:41 pm
BHLLBCRGN
SubscriberI solved the "Ans.SceneGraphChart.SceneGraphAddin" problem. PC name only has english letters.(123 or abc).ThanksÂ
March 27, 2019 at 5:50 pm
March 27, 2019 at 7:52 pm
tsiriaks
Ansys EmployeeHi azadyyilmaz ,
Please start a new thread for your issue.
I will go ahead and lock this thread now.
Thanks,
Win
December 17, 2022 at 7:43 pm
ismail kızılkurt
SubscriberAns.SceneGraphChart.SceneGraphAddin hatası alıyorum nasıl çözebilirim
- The topic ‘Ans.SceneGraphChart.SceneGraphAddin’ is closed to new replies.
5639
1885
1403
1298
.jpg?width=690&upscale=false)
