May 29, 2025 at 8:12 pm
patton
SubscriberHello, is it possible to define anisotropic optical materials in FEEM?
Thank You
May 30, 2025 at 7:05 am
Dimitris Polyzos
Ansys EmployeeHello
yes the FEEM solver supports spatially varying isotropic and diagonally anisotropic materials. You have to create a (.mat) file with unstructured dataset. Then import it with importdataset script command can also be used to import spatially varying index data into nk import object.. Please have a look at the following links:
nk-material-finite-element-Simulation-object
Spatial-n-k-data-Simulation-object
The following link is for FTDD and MODE that use rectilinear mesh, but you can have a look and get some information from them.
Creating-anisotropic-optical-materials-in-FDTD-and-MODE
I hope I helped.
Dimitris
May 30, 2025 at 7:06 am
Dimitris Polyzos
Ansys EmployeeSorry I forgot to share another useful link L
Lithium-Niobate-Nonlinear-Thermal-Waveguide-FEEM
Regards
May 30, 2025 at 3:24 pm
patton
SubscriberI will take a look at these, thank you!
3236
1031
969
859
798
