November 16, 2023 at 7:52 pm
Seyed AmirMahdi Mirhosseini
SubscriberHello
Problem: I'm solving a single Heat Flow applying on a surface in which I want to see the Temperature Distrubition at the end of it.
Problem is, this whole process should be done in only 1 second as my Heat Flow is in Watts (Joules per second), I'm using Tabular asÂ
but I want to divide this 1 second into different steps. so for example:
1 second into 20, the time should start from 0.05 and each step 0.05 adds to previous one until it reaches 1 second and the end. But I don't know how to step-up my analysis setting under Transient Thermal to achieve this. -
November 16, 2023 at 10:20 pm
- The topic ‘Analysis Setting – Transient Thermal’ is closed to new replies.
Ansys Innovation Space
1333
1168
1090
1014
