August 21, 2019 at 6:51 am
August 21, 2019 at 3:32 pm
Hui Liu
Forum Moderator Hi ilham,
You can specify whatever frequency you are interested in, eg if you run your experiment at range of 1000-2000 Hz, you can set up the same range in your simulation. However keep in mind the mesh size should change based on your frequency too. You need to have 12 elem per wavelength for linear element and 6 elem per wavelength for quadratic element.
- The topic ‘Analysis Setting of Muffler’ is closed to new replies.
1859
1398
1256
