Analysis Result Export
    • Jeonee
      I want to export my analysis result as .stp or parasolid. How can I do it? It allows as .stl
    • Akshay Maniyar
      Hi Jeone,
      The only file format available for export from Mechanical is.STL. In order to clean and build the solid from the faceted geometry, you will need to import it back into SC. You can then export in the desired format, such as stp or Parasolid, after that.
      Thanks,
      Akshay Maniyar
      • Jeonee
        Thank you
  • The topic ‘Analysis Result Export’ is closed to new replies.
