December 7, 2018 at 7:50 am
Pavel
SubscriberHallo!
I have a problem with my last step in ANSYS 19.0 (academic version) in solution (Solve). I tried to create a very simple geomerty but I still getting error:Â
"An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes."
In "Solver Output" I found following error:
"*** FATAL ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â Â 0.187Â Â TIME= 08:59:11
 The memory (-m) size requested [2112 mb] is not currently available.  Â
 Reenter ANSYS command line with less memory requested."
How to fix this? What shall I do?
Could you help me, please!
December 7, 2018 at 1:05 pm
jpasquerell
Ansys EmployeeLeave the program do the memory management so no -m or -db on when you start the program.Â
December 7, 2018 at 2:15 pm
peteroznewman
SubscriberHello Pavel,
Does your computer have 4 GB of RAM? If so, Restart your computer, open only ANSYS, and try again. Sometimes, if you have a lot of other programs open or if you have not restarted in a long time, there is no longer a block of memory large enough for ANSYS to use.
The hardware requirements for ANSYS is a minimum of 4 GB of RAM. If your computer has less than 4 GB of RAM, reply with what you have. There are ways to tell ANSYS to request a smaller memory size if you have a small model. I saw this sometimes on the edX course where students with even 2GB of RAM could run the small models in that course. Â
Peter -
April 28, 2019 at 8:29 pm
user deleted
SubscriberHello! Please help me. I have 4 GB of RAM, but my computer says that my task cannot be solved. What should i do?
April 29, 2019 at 4:54 am
user deleted
SubscriberHello! Please help me. I have 4 GB of RAM, but my computer says that my task cannot be solved. What should i do? -
April 29, 2019 at 10:52 am
Forum ModeratorWe work in several time zones so please be patient: Peter is in the US. Â
What happens if you open ANSYS and then only Mechanical? Have you also shut down mail tools, web browsers etc?Â
April 29, 2019 at 11:00 am
peteroznewman
SubscriberAlexander, there are many reasons why a task cannot be solved.
Please reply with screen images inserted into the post of the error.
Your error may not be the same as Pavel's.Â
Did you restart your computer and open only Mechanical? -
May 27, 2020 at 1:50 am
buchancr
SubscriberI am experiencing a similar issue, I am trying to increase the resolution of my mesh. When I change my mesh resolution from the default setting and try and solve it gives me the same error. Even if I change the default mesh size from default to 2 (which is the default), then it gives me the error. I am using ansys through a virtual machine and every program I have running is closed except for the browser through which I am accessing ansys on the virtual machine. I only have open ansys and mechanical. Any help would be appreciated.
I can get the default to run
But I can't get this to run
Here is the solution information error
- The topic ‘An unknown error with memory occurred during solution.’ is closed to new replies.
5669
1890
1419
1304
