March 9, 2019 at 4:09 am
Isahi0161
SubscriberAnsys worked great before but then suddenly I started receiving this message. I tried going back and redoing several other problems with different parameters but kept getting same error message. Can I get anyone to help? Please and thank you.
March 9, 2019 at 7:35 am
sathya
SubscriberHi In the solver directory open error file and identify the problem. -
March 10, 2019 at 3:28 am
Isahi0161
Subscriber/COM,ANSYS RELEASE Release 19.2Â Â Â Â Â BUILD 19.2Â Â Â Â Â UP20180808Â Â Â Â Â Â 22:26:10
 *** FATAL ***                          CP =      0.359  TIME= 22:26:11
 The memory (-m) size requested [2112 mb] is not currently available onÂ
 one of the other Distributed ANSYS processes. Reenter ANSYS command  Â
 line with less memory requested.                                      Â
 The above error is non-recoverable by ANSYS                           Â
 ANSYS run terminated by the indicated error                          Â
 Current data base saved if possible.                                 Â
March 10, 2019 at 4:37 pm
sathya
SubscriberHi Play with memory settings in Ansys product launcher window.
Additional info can be found at
https://www.sharcnet.ca/Software/Ansys/17.2/en-us/help/ans_bas/Hlp_G_BAS19_5.html -
March 10, 2019 at 4:39 pm
peteroznewman
SubscriberDid you restart your computer to see if that helped?
March 10, 2019 at 9:06 pm
Isahi0161
SubscriberThe website you linked says it doesn't exist.
March 11, 2019 at 9:36 am
- The topic ‘An unknown error occurred during solution. Check the Solver Output on the Solution Information’ is closed to new replies.
3572
1188
1076
1063
952
