November 24, 2019 at 2:28 pm
hanimamoo
SubscriberHey guys , just having a problem in solving a Baja chassis in Static Sturctural. Mesh is generated but the following error keep coming up. I have solved similar structures in the same devicie without any problem .
Have attached the solution information. Thanks in advance.
Text: "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes."
Association: "Project>Model>Static Structural>Solution"
November 24, 2019 at 5:33 pm
peteroznewman
SubscriberThe attached text file is empty.
November 24, 2019 at 5:38 pm
hanimamoo
SubscriberSorry for that. Have uploaded it now. Please have a look at it. Thank you.
November 24, 2019 at 5:48 pm
peteroznewman
SubscriberThe error is found in the file.
*** ERROR *** CP = 16.875 TIME= 19:56:26
The normal of target element 353259 is not consistent with the normal
of target element 353260 in real set 251. Please use the ENORM
command to correct it.
*** ERROR *** CP = 17.328 TIME= 19:56:26
The normal of contact element 353090 is not consistent with the normal
of contact element 353091 in real set 252. Please use the ENORM
You could create a Named Selection using the Worksheet to find these two pair of elements.
It could be that the wrong side of a face was picked in the contact definition.
It may be possible to flip the face normal in a CAD system.
Or you could figure out how to use the ENORM command.
November 24, 2019 at 6:00 pm
hanimamoo
SubscriberThanks. WIll try to solve the issue and follow-up here !
- The topic ‘an unknown error occurred during solution. check the solver output’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4032
1461
