March 2, 2020 at 4:28 pm
harsf
SubscriberI get the error "an unknown error occurred during solution. check the solver output on the solution information problem for possible causes"
My model deals with fluid - structure interaction when an earthquake load is applied. can someone comment to solve the problemÂ
March 3, 2020 at 11:02 am
Aniket Chavan
Forum ModeratorDid you check the solution information aka solve.out file in the project directory? What error do you get?
-Aniket
March 3, 2020 at 4:02 pm
harsf
SubscriberThanks for replying. Below is the error. I'm also attaching some images
"The license is currently in use by another application in this Workbench session such as Mechanical or another Mechanical APDL application. You must wait until the other application has finished its task (for example meshing) or manually PAUSE the other Mechanical APDL application "
I only have 19 R3 version , and no any other application is running.. Can anyone tell me the reason?
March 4, 2020 at 4:29 pm
Aniket Chavan
Forum ModeratorTry restarting your machine.Â
March 8, 2020 at 2:36 am
harsf
Subscriberit might be a solution, then another error popped.. Thanks alotÂ
- The topic ‘an unknown error occurred during solution’ is closed to new replies.
5669
1890
1419
1304
