December 20, 2024 at 12:24 am
mc19635
I dont know why this cannot be solved. I have no errors in the solytion information and only 1 warning.Ansys Mechanical Enterprise Academic Student
| W E L C O M E T O T H E A N S Y S (R) P R O G R A M |
* ANSYS MAPDL 2024 R2 LEGAL NOTICES *
* Copyright 1971-2024 Ansys, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of Ansys, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the Ansys, Inc. online documentation or the Ansys, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* Ansys, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* Ansys, Inc. is a UL registered *
* ISO 9001:2015 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the Ansys, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the Ansys, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
2024 R2
Point Releases and Patches installed:
Ansys Service Pack 2024 R2.9175040
Discovery 2024 R2.9175040
Core WB Files 2024 R2.9175040
Ansys Dynamic Reporting 2024 R2.9175040
SpaceClaim 2024 R2.9175040
CFX (includes CFD-Post) 2024 R2.9175040
Chemkin 2024 R2.9175040
EnSight 2024 R2.9175040
FENSAP-ICE 2024 R2.9175040
Fluent (includes CFD-Post) 2024 R2.9175040
Polyflow (includes CFD-Post) 2024 R2.9175040
Forte (includes EnSight) 2024 R2.9175040
TurboGrid 2024 R2.9175040
ACIS Geometry Interface 2024 R2.9175040
AutoCAD Geometry Interface 2024 R2.9175040
Catia, Version 4 Geometry Interface 2024 R2.9175040
Catia, Version 5 Geometry Interface 2024 R2.9175040
Catia, Version 6 Geometry Interface 2024 R2.9175040
Creo Elements/Direct Modeling Geometry Interface 2024 R2.9175040
Creo Parametric Geometry Interface 2024 R2.9175040
Inventor Geometry Interface 2024 R2.9175040
JTOpen Geometry Interface 2024 R2.9175040
NX Geometry Interface 2024 R2.9175040
Parasolid Geometry Interface 2024 R2.9175040
Solid Edge Geometry Interface 2024 R2.9175040
SOLIDWORKS Geometry Interface 2024 R2.9175040
Speos 2024 R2.9175040
Aqwa 2024 R2.9175040
Autodyn 2024 R2.9175040
Material Calibration App 2024 R2.9175040
Customization Files for User Programmable Features 2024 R2.9175040
Mechanical Products 2024 R2.9175040
Motion 2024 R2.9175040
Academic Student 2024 R2.9175040
***** MAPDL COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
DISTRIBUTED MEMORY PARALLEL REQUESTED
4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
TOTAL OF 4 CORES REQUESTED
INPUT FILE NAME = D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E\dummy.dat
OUTPUT FILE NAME = D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E\solve.out
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
RELEASE= 2024 R2 BUILD= 24.2 UP20240513 VERSION=WINDOWS x64
CURRENT JOBNAME=file0 02:10:44 DEC 20, 2024 CP= 0.062
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
*** NOTE *** CP = 0.484 TIME= 02:10:45
The /CONFIG,NOELDB command is not valid in a distributed memory
parallel solution. Command is ignored.
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 2.17916667
TITLE=
periptwsh1--Steady-State Thermal (B5)
ACT Extensions:
LSDYNA, 2024.2
5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
/COM, ANSYSMotion, 2024.2
20180725-3f81-49eb-9f31-41364844c769, wbex
--- Data in consistent MKS units. See Solving Units in the help system for more
MKS UNITS SPECIFIED FOR INTERNAL
LENGTH (l) = METER (M)
MASS (M) = KILOGRAM (KG)
TIME (t) = SECOND (SEC)
TEMPERATURE (T) = CELSIUS (C)
TOFFSET = 273.0
CHARGE (Q) = COULOMB
FORCE (f) = NEWTON (N) (KG-M/SEC2)
HEAT = JOULE (N-M)
PRESSURE = PASCAL (NEWTON/M**2)
ENERGY (W) = JOULE (N-M)
POWER (P) = WATT (N-M/SEC)
CURRENT (i) = AMPERE (COULOMBS/SEC)
CAPACITANCE (C) = FARAD
INDUCTANCE (L) = HENRY
MAGNETIC FLUX = WEBER
RESISTANCE (R) = OHM
ELECTRIC POTENTIAL = VOLT
INPUT UNITS ARE ALSO SET TO MKS
*** MAPDL - ENGINEERING ANALYSIS SYSTEM RELEASE 2024 R2 24.2 ***
01055371 VERSION=WINDOWS x64 02:10:45 DEC 20, 2024 CP= 0.531
***** MAPDL ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Elements for Body 1 'Solid' ***********
*********** Elements for Body 2 'Solid' ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Send Materials ***********
*********** Define Temperature Constraint ***********
*********** Create "ToSurface(Open)" Radiation ***********
***************** Define Uniform Initial temperature ***************
***** ROUTINE COMPLETED ***** CP = 1.391
--- Number of total nodes = 52201
--- Number of contact elements = 0
--- Number of spring elements = 0
--- Number of bearing elements = 0
--- Number of solid elements = 9332
--- Number of condensed parts = 0
--- Number of total elements = 9332
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 2.17916667
************************* SOLUTION ********************************
***** MAPDL SOLUTION ROUTINE *****
PERFORM A STATIC ANALYSIS
THIS WILL BE A NEW ANALYSIS
CONTACT INFORMATION PRINTOUT LEVEL 1
CHECK INITIAL OPEN/CLOSED STATUS OF SELECTED CONTACT ELEMENTS
AND LIST DETAILED CONTACT PAIR INFORMATION
SPLIT CONTACT SURFACES AT SOLVE PHASE
NUMBER OF SPLITTING TBD BY PROGRAM
DO NOT SAVE ANY RESTART FILES AT ALL
DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
******************* SOLVE FOR LS 1 OF 1 ****************
SPECIFIED CONSTRAINT TEMP FOR PICKED NODES
REAL= 500.000000 IMAG= 0.00000000
REAL= 1200.00000 IMAG= 0.00000000
SPECIFIED SURFACE LOAD RDSF FOR ALL PICKED ELEMENTS LKEY = 6 KVAL = 1
VALUES = 0.60000 0.60000 0.60000 0.60000
SPECIFIED SURFACE LOAD RDSF FOR ALL PICKED ELEMENTS LKEY = 6 KVAL = 2
VALUES = 1.0000 1.0000 1.0000 1.0000
ALL SELECT FOR ITEM=NODE COMPONENT=
IN RANGE 1 TO 52201 STEP 1
52201 NODES (OF 52201 DEFINED) SELECTED BY NSEL COMMAND.
ALL SELECT FOR ITEM=ELEM COMPONENT=
IN RANGE 1 TO 9332 STEP 1
9332 ELEMENTS (OF 9332 DEFINED) SELECTED BY ESEL COMMAND.
REAL= 26.8500000 IMAG= 0.00000000
VALUES = 0.20000 0.20000 0.20000 0.20000
PRINTOUT RESUMED BY /GOP
USE AUTOMATIC TIME STEPPING THIS LOAD STEP
USE 1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
FOR AUTOMATIC TIME STEPPING:
USE 10 SUBSTEPS AS A MAXIMUM
USE 1 SUBSTEPS AS A MINIMUM
TIME= 1.0000
ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
FOR ALL APPLICABLE ENTITIES
WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE FFLU ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE MISC ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
CONVERGENCE ON HEAT BASED ON THE NORM OF THE N-R LOAD
WITH A TOLERANCE OF 0.1000E-03 AND A MINIMUM REFERENCE VALUE OF 0.1000E-05
USING THE L2 NORM (CHECK THE SRSS VALUE)
UNDER RELAXATION FOR RADIATION FLUX= 0.10000
TOLERENCE FOR RADIOSITY FLUX= 0.00010
USING JACOBI ITERATIVE SOLVER FOR RADIOSITY SOLUTION
FOR 3D ENCLOSURES.
USING GSEIDEL ITERATIVE SOLVER FOR RADIOSITY SOLUTION
FOR 2D ENCLOSURES.
MAXIMUM NUMBER OF ITERATIONS= 1000
TOLERENCE FOR ITERATIVE SOLVER= 0.10000
RELAXATION FOR ITERATIVE SOLVER= 0.10000
HEMICUBE RESOLUTION= 10
MIN NORMALIZED DIST BEFORE AUTO SUBDIVIDE= 1.000000000E-06
SELECT COMPONENT _CM38
SELECT ALL ELEMENTS HAVING ANY NODE IN NODAL SET.
2333 ELEMENTS (OF 9332 DEFINED) SELECTED FROM
7108 SELECTED NODES BY ESLN COMMAND.
BEFORE SYMMETRIZATION:
NUMBER OF RADIATION NODES CREATED = 2388
NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED = 2333
AFTER SYMMETRIZATION:
FULL NUMBER OF RADIATION NODES CREATED = 2388
FULL NUMBER OF RADIOSITY SURFACE ELEMENTS CREATED = 2333
IN RANGE 1 TO 54589 STEP 1
54589 NODES (OF 54589 DEFINED) SELECTED BY NSEL COMMAND.
IN RANGE 1 TO 11665 STEP 1
11665 ELEMENTS (OF 11665 DEFINED) SELECTED BY ESEL COMMAND.
SELECT COMPONENT _CM39
2333 ELEMENTS (OF 11665 DEFINED) SELECTED FROM
IN RANGE 1 TO 56977 STEP 1
56977 NODES (OF 56977 DEFINED) SELECTED BY NSEL COMMAND.
IN RANGE 1 TO 13998 STEP 1
13998 ELEMENTS (OF 13998 DEFINED) SELECTED BY ESEL COMMAND.
*GET ANSINTER_ FROM ACTI ITEM=INT VALUE= 0.00000000
*IF ANSINTER_ ( = 0.00000 ) NE
0 ( = 0.00000 ) THEN
*ENDIF
*** NOTE *** CP = 1.688 TIME= 02:10:45
The automatic domain decomposition logic has selected the MESH domain
decomposition method with 4 processes per solution.
***** MAPDL SOLVE COMMAND *****
CALCULATING VIEW FACTORS USING HEMICUBE METHOD
RETRIEVED 1 ENCLOSURES.
TOTAL OF 4666 DEFINED ELEMENT FACES.
# ENCLOSURE = 1 # SURFACES = 4666 # NODES = 4776
TIME OF CALCULATION FOR THIS ENCLOSURE = 1.39062
CHECKING VIEW FACTOR SUM
VIEW FACTOR CALCULATION COMPLETE
WRITING VIEW FACTORS TO FILE file0.vf
VIEW FACTORS WERE WRITTEN TO FILE file0.vf
*** WARNING *** CP = 3.375 TIME= 02:10:47
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** NOTE *** CP = 3.500 TIME= 02:10:47
The model data was checked and warning messages were found.
Please review output or errors file ( D:\θερμικη
ακτινοβολια\_ProjectScratch\ScrAB2E\file0.err ) for these warning
messages.
01055371 VERSION=WINDOWS x64 02:10:47 DEC 20, 2024 CP= 3.500
S O L U T I O N O P T I O N S
PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
DEGREES OF FREEDOM. . . . . . TEMP
ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15
GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
*** NOTE *** CP = 3.547 TIME= 02:10:47
This nonlinear analysis defaults to using the full Newton-Raphson
solution procedure. This can be modified using the NROPT command.
The conditions for direct assembly have been met. No .emat or .erot
files will be produced.
D I S T R I B U T E D D O M A I N D E C O M P O S E R
...Number of elements: 13998
...Number of nodes: 56977
...Decompose to 4 CPU domains
...Element load balance ratio = 1.001
L O A D S T E P O P T I O N S
LOAD STEP NUMBER. . . . . . . . . . . . . . . . 1
TIME AT END OF THE LOAD STEP. . . . . . . . . . 1.0000
AUTOMATIC TIME STEPPING . . . . . . . . . . . . ON
INITIAL NUMBER OF SUBSTEPS . . . . . . . . . 1
MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . . 10
MINIMUM NUMBER OF SUBSTEPS . . . . . . . . . 1
MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . . 15
STEP CHANGE BOUNDARY CONDITIONS . . . . . . . . NO
TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
CONVERGENCE CONTROLS
LABEL REFERENCE TOLERANCE NORM MINREF
HEAT 0.000 0.1000E-03 2 0.1000E-05
PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
DATABASE OUTPUT CONTROLS
ITEM FREQUENCY COMPONENT
ALL NONE
NSOL ALL
RSOL ALL
EANG ALL
VENG ALL
FFLU ALL
CONT ALL
MISC ALL
SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS HAS BEEN MODIFIED
TO BE, NEQIT = 1000, BY SOLUTION CONTROL LOGIC.
RADIOSITY SOLVER CALCULATION
ENCLOSURE NUMBER= 1
RADIOSITY SOLVER CONVERGED AFTER 108 ITERATIONS
TIME OF RADIOSITY SOLVER FOR ENCLOSURE= 0.781250
RAD FLUX CONVERGENCE VALUE= 1.00000 CRITERION= 0.100000E-03
**** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
TOTAL MASS = 532.69
MOM. OF INERTIA MOM. OF INERTIA
CENTER OF MASS ABOUT ORIGIN ABOUT CENTER OF MASS
XC = -0.32759E-05 IXX = 60.31 IXX = 53.26
YC = -0.12722E-04 IYY = 60.30 IYY = 53.26
ZC = 0.11500 IZZ = 95.81 IZZ = 95.81
IXY = 0.1115E-02 IXY = 0.1115E-02
IYZ = 0.7048E-05 IYZ = -0.7723E-03
IZX = 0.2007E-03 IZX = 0.7231E-11
*** MASS SUMMARY BY ELEMENT TYPE ***
TYPE MASS
1 266.344
2 266.344
Range of element maximum matrix coefficients in global coordinates
Maximum = 3.73032644 at element 5243.
Minimum = 0.750584548 at element 9324.
*** ELEMENT MATRIX FORMULATION TIMES
TYPE NUMBER ENAME TOTAL CP AVE CP
1 4666 SOLID279 0.328 0.000070
2 4666 SOLID279 0.344 0.000074
3 2333 SURF252 0.016 0.000007
4 2333 SURF252 0.047 0.000020
Time at end of element matrix formulation CP = 5.234375.
HT FLOW CONVERGENCE VALUE= 0.4233E+06 CRITERION= 42.33
DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
Number of equations = 37984, Maximum wavefront = 60
Memory allocated on only this MPI rank (rank 0)
Equation solver memory allocated = 24.453 MB
Equation solver memory required for in-core mode = 23.494 MB
Equation solver memory required for out-of-core mode = 13.574 MB
Total (solver and non-solver) memory allocated = 613.344 MB
Total memory summed across all MPI ranks on this machines
Equation solver memory allocated = 96.362 MB
Equation solver memory required for in-core mode = 92.580 MB
Equation solver memory required for out-of-core mode = 53.530 MB
Total (solver and non-solver) memory allocated = 1368.296 MB
*** NOTE *** CP = 5.547 TIME= 02:10:49
The Distributed Sparse Matrix Solver is currently running in the
in-core memory mode. This memory mode uses the most amount of memory
in order to avoid using the hard drive as much as possible, which most
often results in the fastest solution time. This mode is recommended
if enough physical memory is present to accommodate all of the solver
data.
Distributed sparse solver maximum pivot= 15.505386 at node 34629 TEMP.
Distributed sparse solver minimum pivot= 0.609744417 at node 4609 TEMP.
Distributed sparse solver minimum pivot in absolute value= 0.609744417
at node 4609 TEMP.
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 1178.
HT FLOW CONVERGENCE VALUE= 0.3042E-09 CRITERION= 0.6702E-02 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 1
ENCLOSURE NUMBER= 1
RADIOSITY SOLVER CONVERGED AFTER 195 ITERATIONS
TIME OF RADIOSITY SOLVER FOR ENCLOSURE= 1.42188
RAD FLUX CONVERGENCE VALUE= 0.993191 CRITERION= 0.100000E-03
HT FLOW CONVERGENCE VALUE= 1318. CRITERION= 0.2051
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -23.38
HT FLOW CONVERGENCE VALUE= 0.9131E-10 CRITERION= 0.2422 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 2
ENCLOSURE NUMBER= 1
RADIOSITY SOLVER CONVERGED AFTER 130 ITERATIONS
TIME OF RADIOSITY SOLVER FOR ENCLOSURE= 1.00000
RAD FLUX CONVERGENCE VALUE= 0.392394E-01 CRITERION= 0.100000E-03
HT FLOW CONVERGENCE VALUE= 45.42 CRITERION= 0.2387
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.8210
HT FLOW CONVERGENCE VALUE= 0.8938E-10 CRITERION= 0.2364 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 3
ENCLOSURE NUMBER= 1
RADIOSITY SOLVER CONVERGED AFTER 60 ITERATIONS
TIME OF RADIOSITY SOLVER FOR ENCLOSURE= 0.406250
RAD FLUX CONVERGENCE VALUE= 0.107705E-02 CRITERION= 0.100000E-03
HT FLOW CONVERGENCE VALUE= 1.358 CRITERION= 0.2365
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2869E-01
HT FLOW CONVERGENCE VALUE= 0.9026E-10 CRITERION= 0.2366 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 4
ENCLOSURE NUMBER= 1
RADIOSITY SOLVER CONVERGED AFTER 12 ITERATIONS
TIME OF RADIOSITY SOLVER FOR ENCLOSURE= 0.468750E-01
RAD FLUX CONVERGENCE VALUE= 0.192367E-04 CRITERION= 0.100000E-03
RADIOSITY FLUX CONVERGED AFTER ITERATION= 5 SUBSTEP= 1
HT FLOW CONVERGENCE VALUE= 0.1922E-01 CRITERION= 0.2366 <<< CONVERGED
*** ELEMENT RESULT CALCULATION TIMES
1 4666 SOLID279 0.203 0.000044
2 4666 SOLID279 0.297 0.000064
3 2333 SURF252 0.047 0.000020
4 2333 SURF252 0.094 0.000040
*** NODAL LOAD CALCULATION TIMES
1 4666 SOLID279 0.125 0.000027
2 4666 SOLID279 0.078 0.000017
3 2333 SURF252 0.031 0.000013
4 2333 SURF252 0.016 0.000007
*** LOAD STEP 1 SUBSTEP 1 COMPLETED. CUM ITER = 4
*** TIME = 1.00000 TIME INC = 1.00000
*** MAPDL BINARY FILE STATISTICS
BUFFER SIZE USED= 16384
1.188 MB WRITTEN ON ELEMENT SAVED DATA FILE: file0.esav
4.688 MB WRITTEN ON ASSEMBLED MATRIX FILE: file0.full
3.312 MB WRITTEN ON RESULTS FILE: file0.rth
*************** Write FE CONNECTORS *********
WRITE OUT CONSTRAINT EQUATIONS TO FILE= file.ce
*************** FINISHED SOLVE FOR LS 1 *************
*GET _WALLASOL FROM ACTI ITEM=TIME WALL VALUE= 2.18222222
FINISH SOLUTION PROCESSING
***** ROUTINE COMPLETED ***** CP = 11.391
01055371 VERSION=WINDOWS x64 02:10:57 DEC 20, 2024 CP= 11.391
***** MAPDL RESULTS INTERPRETATION (POST1) *****
*** NOTE *** CP = 11.391 TIME= 02:10:57
Reading results into the database (SET command) will update the current
displacement and force boundary conditions in the database with the
values from the results file for that load set. Note that any
subsequent solutions will use these values unless action is taken to
either SAVE the current values or not overwrite them (/EXIT,NOSAVE).
Set Encoding of XML File to:ISO-8859-1
Set Output of XML File to:
PARM, , , , , , , , , , , ,
DATABASE WRITTEN ON FILE parm.xml
EXIT THE MAPDL POST1 DATABASE PROCESSOR
*GET _WALLDONE FROM ACTI ITEM=TIME WALL VALUE= 2.18250000
PARAMETER _PREPTIME = 0.000000000
PARAMETER _SOLVTIME = 11.00000000
PARAMETER _POSTTIME = 1.000000000
PARAMETER _TOTALTIM = 12.00000000
*GET _DLBRATIO FROM ACTI ITEM=SOLU DLBR VALUE= 1.00057159
*GET _COMBTIME FROM ACTI ITEM=SOLU COMB VALUE= 0.895214000E-01
*GET _SSMODE FROM ACTI ITEM=SOLU SSMM VALUE= 2.00000000
*GET _NDOFS FROM ACTI ITEM=SOLU NDOF VALUE= 37984.0000
/FCLEAN COMMAND REMOVING ALL LOCAL FILES
--- Total number of nodes = 52201
--- Total number of elements = 9332
--- Element load balance ratio = 1.00057159
--- Time to combine distributed files = 8.95214E-02
--- Sparse memory mode = 2
--- Number of DOF = 37984
EXIT MAPDL WITHOUT SAVING DATABASE
NUMBER OF WARNING MESSAGES ENCOUNTERED= 1
NUMBER OF ERROR MESSAGES ENCOUNTERED= 0
+--------------------- M A P D L S T A T I S T I C S ------------------------+
Release: 2024 R2 Build: 24.2 Update: UP20240513 Platform: WINDOWS x64
Date Run: 12/20/2024 Time: 02:10 Process ID: 2388
Operating System: Windows 10 (Build: 19045)
Processor Model: Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz
Compiler: Intel(R) Fortran Compiler Classic Version 2021.9 (Build: 20230302)
Intel(R) C/C++ Compiler Classic Version 2021.9 (Build: 20230302)
Intel(R) oneAPI Math Kernel Library Version 2023.1-Product Build 20230303
Number of machines requested : 1
Total number of cores available : 4
Number of physical cores available : 4
Number of processes requested : 4
Number of threads per process requested : 1
Total number of cores requested : 4 (Distributed Memory Parallel)
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.11 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
Core Machine Name Working Directory
0 DESKTOP-PF0E6CC D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E
1 DESKTOP-PF0E6CC D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E
2 DESKTOP-PF0E6CC D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E
3 DESKTOP-PF0E6CC D:\θερμικη ακτινοβολια\_ProjectScratch\ScrAB2E
Latency time from master to core 1 = 5.192 microseconds
Latency time from master to core 2 = 15.481 microseconds
Latency time from master to core 3 = 14.342 microseconds
Communication speed from master to core 1 = 1088.11 MB/sec
Communication speed from master to core 2 = 1684.70 MB/sec
Communication speed from master to core 3 = 896.47 MB/sec
Total CPU time for main thread : 10.1 seconds
Total CPU time summed for all threads : 11.6 seconds
Elapsed time spent obtaining a license : 0.5 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.2 seconds
Elapsed time spent solution - preprocessing : 0.3 seconds
Elapsed time spent computing solution : 8.7 seconds
Elapsed time spent solution - postprocessing : 0.1 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Equation solver used : Sparse (symmetric)
Equation solver computational rate : 11.0 Gflops
Sum of disk space used on all processes : 43.4 MB
Sum of memory used on all processes : 746.0 MB
Sum of memory allocated on all processes : 3246.0 MB
Physical memory available : 8 GB
Total amount of I/O written to disk : 0.0 GB
Total amount of I/O read from disk : 0.0 GB
+------------------ E N D M A P D L S T A T I S T I C S -------------------+
| RUN COMPLETED |
| Ansys MAPDL 2024 R2 Build 24.2 UP20240513 WINDOWS x64 |
| Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB |
| Max Database Used(Master) 34 MB Max Scratch Used(Master) 187 MB |
| Max Database Used(Workers) 1 MB Max Scratch Used(Workers) 174 MB |
| Sum Database Used(All) 37 MB Sum Scratch Used(All) 709 MB |
| CP Time (sec) = 11.641 Time = 02:10:58 |
| Elapsed Time (sec) = 15.000 Date = 12/20/2024 |
*-----------------------------------------------------------------------------*Thank you for your time and effort!
December 23, 2024 at 11:00 am
Lydia Lymperopoulou
Ansys EmployeeHello, it seems like you analysis has solved for loadstep 1. Do you have more load steps in your analysis? Can you try supressing the result objects you have inserted and try again?
