October 22, 2024 at 2:23 pm
October 22, 2024 at 2:42 pm
harshvardhan.negi
Ansys EmployeeHi,
It will be better if you would share what error you are getting in Solver Output. In Solver Output search (ctrl + F) for error and share the screenshot of the error detail.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
October 22, 2024 at 3:06 pm
maabbas
Subscriber*** NOTE ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â 35.078Â Â TIME= 13:02:45
 The model data was checked and warning messages were found.           Â
 Please review output or errors file (                                Â
 D:\Concrete-Precompression\Final-ActualSpring\_ProjectScratch\ScrDF8A\f
 file0.err ) for these warning messages.     ÂÂ
*** NOTE ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â Â 35.609Â Â TIME= 13:02:45
 The step data was checked and warning messages were found.            Â
 file0.err ) for these warning messages.ÂÂ
*** NOTE ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â Â 427.312Â Â TIME= 13:09:18
 file0.err ) for these warning messages.                               Â However the I do have this folder in my directory even with showing the hidden filesÂ
October 22, 2024 at 3:24 pm
maabbas
SubscriberI found this in the file0.err
/COM,ANSYS RELEASE 2023 R1 Â Â Â Â Â BUILD 23.1 Â Â Â UP20221128 Â Â Â 13:02:35
 *** WARNING ***             CP =    34.406  TIME= 13:02:44
 Element shape checking is currently inactive.  Issue SHPP,ON or     Â
 SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =    35.609  TIME= 13:02:45
 Material number 13 (used by element 167206) should normally have at   Â
 least one MP or one TB type command associated with it.  Output of   Â
 energy by material may not be available.                Â *** WARNING ***             CP =    38.844  TIME= 13:02:49
 Maximum friction coefficient 0.6 is defined in the model.  Switch to  Â
 the unsymmetric solver (NROP,UNSYM) instead if convergence difficulty  Â
 is encountered.                             Â *** WARNING ***             CP =   427.141  TIME= 13:09:18
 energy by material may not be available.                Â-
October 23, 2024 at 6:21 am
ErKo
Ansys EmployeeHi
Can you run it for a shorter time duration: total time=0.5 E-3 second instead.
Clear all generated data before solving.
All the best
Erik
5849
