February 21, 2023 at 1:38 pm
John Luke
SubscriberI'm doing a strength assessment for a mountain bike frame, my load and boundary conditions are;
1- a remote displacement with all 0 components where the handler is attached to the bike frame
2- Symmetry region
3- a Load tangential to the edge
When I try to solve for equivalent stress it shows these messages.I'm not sure whats the problem if someone could help I would appreciate it.
February 21, 2023 at 1:52 pm
Claudio Pedrazzi
SubscriberWhere is the remote displacement located in the model? please post a screenshot of it too. It seems likely that you are not constraining enough, but I would like to judge after having seen the remote displacement. Is this a shell model?
February 21, 2023 at 1:57 pm
February 21, 2023 at 2:03 pm
Claudio Pedrazzi
SubscriberSeems fine to me, though I do not really understand the symmetry, since you fix everything.
But just for testing. If you substitute your remote displacement wiht a simple fixed constraint on that cylindrical surface, hopefully the problem disappears? It would be a first hint.
February 21, 2023 at 2:10 pm
February 21, 2023 at 2:19 pm
Claudio Pedrazzi
Subscriberok thank you for the clarification, at this point I have no other ideas. My point about symmetry I need to explain it better. That is, if I have understood the situation correctly. In my sketch (I apologize for the bad quality) the two flags represent a symmetry condition.
What I am saying is that if in the plane of symmetry every displacement and rotation is fixed (as I understood from your remote displacement), then the symmetry condition is not necessary, it is “implicit”. Because no stress will get beyond your fixed point, no matter what type of loads you have. But this does not answer your problem, I know. It was just a side comment. But I would delete the symmetry condition anyway.
February 21, 2023 at 2:24 pm
February 21, 2023 at 2:34 pm
ErKo
Ansys EmployeeHi
Can you check as it says the load might be wrong (and in combination with material properties) – try and solve for 0.0001 N.
All the best
Erik
February 21, 2023 at 6:46 pm
wrbulat
Ansys EmployeeHere's something I always remember to forget to do in cases like this - duplicate the static structural system, convert it to a modal one, and solve for a few natural frequencies. Look for zero or near-zero natural frequencies and associated rigid body modes. This can be used to identify the motion that your presumably inadequate constraints allow and shine a light on what needs to be done to fix them. Also, please look closely at your mesh. From the forgoing discussion and images (thanks for these!) I frankly cannot see how this would be possible, but your model almost acts as if it isn't joined by nodal connectivity - like there is a dissimilar mesh at an interface and no bonded contact to structurally connect the meshes at the interface.
Cheers,
Bill
February 22, 2023 at 10:46 am
John Luke
SubscriberIt turned out that I had a simple mistake in the material assigment and when I gave the correct value for the young's modulus everything is behaving properly.
Thanks everyone for your help. -
February 22, 2023 at 10:50 am
ErKo
Ansys EmployeeThat is great - happy it helped.
Erik
- The topic ‘An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid’ is closed to new replies.
5934
1306
