An internal solution magnitude limit was exceeded.
    • Nabhas Revi Kumar
      Hi I'm new to Ansys and Idoing a 2-D elasto-plastic simulation of a bolt and this error comes up:
      "An internal solution magnitude limit was exceeded. (Node Number 15436, Body Part 18, DOF UX) Please check your Environment for inappropriate load values or insufficient supports.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.  Please see the Troubleshooting section of the Help System for more information."
      I've tried solutions in other threads that mention the same error message but none of them work for me, Please tell me what I can do to fix this.
    • Nabhas Revi Kumar
      Hi again, I fixed the issue, added Share Topology in Design Modeller and the error disappeared.
    • ErKo
      That is great - thanks for letting us know - closing as this might help other users in the future.
  • The topic ‘An internal solution magnitude limit was exceeded.’ is closed to new replies.
