April 30, 2025 at 8:54 am
1802039
SubscriberHello,
I am trying to learn heat transfer simulation from innovation course. I have downloaded the materials from this course-"https://innovationspace.ansys.com/courses/courses/heat-transfer/lessons/homework-quizzes-simulation-examples-overview-of-heat-transfer/". After downloading and rerunning the given save file I get this error- "An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Â Please see the Troubleshooting section of the Help System for more information. An internal solution magnitude limit was exceeded. (Node Number 2021, Body Solid, DOF TEMP) Please check your Environment for inappropriate load values or insufficient supports. Â You may select the offending object and/or geometry via RMB on this warning in the Messages window. Â Please see the Troubleshooting section of the Help System for more information."Here is the content data-"https://ansys13.ansys.com/AnsysInnovationCourses/MBU/HeatTransfer/HeatTransferOverview/SE02ThermalAnalysisOfHeatPot.zip".
I am trying best but can't find any possible solution. I even didn't change any data in the save file, just cleared the generated data and re-run it. I am using Ansys 2024 R2.
Can anyone help to troubleshoot?
Thank you.
June 24, 2025 at 5:19 am
Ashish Khemka
Forum ModeratorHello,
I assume this issue was resolved. Please let me know if you have any queries.
Ashish Khemka
- how to create rays of light passing across a hollow cylinder
- Innovation Course Stress Analysis in Solid Mechanics
- Not able to get my Badge of the learning track
- Why cylindrical coordinate system is rotated
- Intro to Ansys APDL Scripting Course – Solid Meshing Lesson 3
- Inertia Relief Analysis of Fixed Wing Drone
- Geometry prep for structural simulation using Ansys discovery, Bracket tutorial
6039
