Ansys Products
Ansys Products
An error occurred while starting the solver module on ANSYS Academic Student 2019 R1
    • luisdamed
      I am getting the message "An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide for more information" whenever I try to solve any type of Thermal or Mechanical analysis. I already have read all the posts I could find and nothing helped.
      It happens for all the ANSYS projects that I created a year ago using v18 (can't remember exactly which one). My laptop is a Windows 10, 64-bit system and I have plenty of Hard drive space and RAM memory and administrative privileges. I even performed a "soft-reset" and installed version Academic Student 2019 R1 - neither my previous projects or new ones work.
       Can anyone help, please? Thanks
      Luis
    • luisdamed
      Additional facts:
      • When I open the solver directory, there is no Solver.out file.
      • All the folders have only English characters, as well as my user and computer IDs
      • Renaming the C:UsersluisdAppDataRoamingAnsys v193 file to v193.old did not work.
      •  I checked the name references for the loads and boundary conditions and none of them were modified from one release to another.
      • I managed to use FLUENT, though, but I can't open it from the workbench window and have to use the CMD:
                                   cd C:Program FilesANSYS IncANSYS Studentv193fluentntbinwin64
                                   fluent ^-r19.3.0 2ddp -meshing -tm8 -t8
      Here is the output from a CMD license check:
      Microsoft Windows [Version 10.0.18362.476]
      (c) 2019 Microsoft Corporation. All rights reserved.
      C:Usersluisd>"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout ANS_SOLVER
      2019/11/22 178:09    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
      ANS_SOLVER OUT id=DESKTOP-JFRKGAF-LuisD-22052-012666 shared_info=DESKTOP-JFRKGAF-LuisD-22052-012667 is_sharable=yes server=53917@localhost is_academic=yes has_academic_logo=yes max_h_elem=0 max_nodes=0 max_faces=0 max_bodies=0 max_species=0 min_cell_size=0 max_depth=0
              Resolved by Feature: id=183 feature=aa_t_i product=ANSYS Academic Teaching Introductory
      Here is the output when opening Mechanical APDL:
      2019/11/23 105:24    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
       2019 R1
       Point Releases and Patches installed:
      FENSAP-ICE 2019 R1
                *****  ANSYS COMMAND LINE ARGUMENTS  *****
        INITIAL JOBNAME              = file
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     2 CORES REQUESTED
        DESIGNXPLORER REQUESTED
        MPI OPTION                   = INTELMPI
        START-UP FILE MODE           = READ
        STOP FILE MODE               = READ
        GRAPHICS DEVICE REQUESTED    = win32
        GRAPHICAL ENTRY              = YES
        LANGUAGE                     = en-us
        INITIAL DIRECTORY = C:Usersluisd
       RELEASE= 2019 R1              BUILD= 19.3      UP20181204   VERSION=WINDOWS x64
       CURRENT JOBNAME=file0  105:26  NOV 23, 2019 CP=      1.109
       /SHOW SET WITH DRIVER NAME= WIN32   ,  RASTER MODE,  GRAPHIC PLANES =  8
       RUN SETUP PROCEDURE FROM FILE= C:Program FilesANSYS IncANSYS Studentv193ANSYSapdlstart.ans
       /INPUT FILE= menust.tmp  LINE=       0
       /INPUT FILE= C:Program FilesANSYS IncANSYS Studentv193ANSYSapdlstart.ans  LINE=       0
       ACTIVATING THE GRAPHICAL USER INTERFACE (GUI).  PLEASE WAIT...
       *** NOTE ***                            CP =       1.656   TIME= 105:26
       The directory "CUsers/luisd/AppData/Roaming/Ansys/ansys19.3" has been
       created to maintain ANSYS settings.
       CUTTING PLANE SET TO THE WORKING PLANE
       PRODUCE NODAL PLOT IN DSYS=  0
       TURN OFF WORKING PLANE DISPLAY
      Honestly, I never tried opening Mechanical APDL before.
    • luisdamed
      •  I managed to solve one of the static structural simulations I made, using Mechanical APDL (thanks to tsiriaks for his advice). However, when reading the results for a transient thermal simulation in Workbench, I get the error
       Your product license has numerical problem size limits, you have exceeded these problem size limits and the solver cannot proceed.
      • I checked the license status from Mechanical APDL and I got this
      ANSYS Licensing Interconnect path is empty.
      Please see the Troubleshooting Section in the ANSYS Licensing Guide for more details.
      ANSYS FLEXlm License path=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic
      ***** Note: Due to a FLEXlm limitation, all tasks may not be found *****
      ____________________________________________________________________
      ***** ANSYS FLEXlm LICENSE SERVER STATUS: C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic *****
        *** ERROR ***
      lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
      Flexible License Manager status on Sat 11/23/2019 14:49
      [Detecting lmgrd processes...]
      Error getting status: No SERVER lines in license file. (-13,66)
      child killed: SIGABRT]
      But I made these simulations with the same type of Ansys Academic license originally, and everything used to solve without problems.
    • tsiriaks
      For your original issue, that happened with ANSYS Mechanical (in Workbench) , right ? not Mechanical APDL  What if you create a brand-new, test static structural project, does this encounter the same issue ? Please post the screenshot of the all relevant errors.
      For the issue with size limit, see this (this is for ANSYS Mechanical but may give some idea for Mechanical APDL)
      /forum/forums/topic/mesh-size-errors-even-if-it-should-work/
    • luisdamed
      Please find the screenshot of the error here below. It happens for any simulation I try to solve with Ansys Mechanical. I've tried Thermal, Structural, Eigenvalue, and always get the same result.
      An error ocurred while starting the solver module
    • tsiriaks
      From your Mechanical GUI above, click Tools -> Write Input File , then save it somewhere.
      Open M-APDL Launcher, specify 'ANSYS Batch' in Simulation Environment and specify the path and file name of your Input File, change Working Directory to C:Temp, then click Run. Post any error that comes up from this.
    • DANUSH DATTHATHIREYAN K
      An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
      help me out
Viewing 6 reply threads
  • The topic ‘An error occurred while starting the solver module on ANSYS Academic Student 2019 R1’ is closed to new replies.
