February 13, 2020 at 5:42 am
marcoaurelio02
SubscriberI was trying to simulate a diffuser, so I founded this problem
"An error occurred while creating the enclosure - 3 bodies could not be subtracted from the enclosure body"
How can I solve this?
Thank you
February 13, 2020 at 11:51 am
Forum ModeratorIt depends on what's causing the problem. As staff I am not permitted to open/download attachments. Can you unite/merge the 3 bodies before you create the enclosure?Â
February 14, 2020 at 4:44 pm
February 17, 2020 at 5:27 am
Keyur Kanade
Ansys EmployeeHello,Â
Right click on geometry in structure tree and use check geometry. Make sure your geometry does not have any errors.Â
From the image, the inner body has some highly curved faces. Can you please re-create those curved faces by creating 3-5 faces and then try to create enclosure.Â
Another option is create a plane parallel to ZY plane and split the geometry in 2 or 3 parts. Create enclosure for each part separately.Â
March 30, 2020 at 8:07 am
March 30, 2020 at 9:25 am
Aniket
Forum ModeratorIrfanPeratama, you would get a better chance of a reply if you open a new thread for a question. And your geometry is not a solid it is just a surface, you will need to create a solid from the surface first.
-Aniket
- The topic ‘An error occurred while creating the enclosure’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
3024
971
857
809
777
