April 11, 2020 at 11:26 pm
uwindsorspz
SubscriberHello all, Â I am working the harmonic response study under the workbench. I import the electromagnetic force from Ansys and all the things are going well. Â After the simulation process, the error comes out and said "An error occurred inside the SOLVER module: general error." Â Is anyone meet the same situation before and how to solve it? Â Thanks. Â Take care. Â Atlas S. -
April 12, 2020 at 12:22 am
peteroznewman
SubscriberOpen the Solution Output (the solve.out file) and read what the error actually is.
April 19, 2020 at 12:09 am
April 20, 2020 at 12:24 am
peteroznewman
SubscriberYou can copy the text around the error and paste that into your reply.
April 20, 2020 at 1:26 am
uwindsorspz
SubscriberI run this simulation again and that error is gone. But there is still some errors shown as below.
 *** WARNING ***                        CP =      1.578  TIME= 21:10:02
 Element shape checking is currently inactive. Issue SHPP,ON or       Â
 SHPP,WARN to reactivate, if desired.                                  Â
 *** NOTE ***                           CP =      1.703  TIME= 21:10:02
 The model data was checked and warning messages were found.           Â
 Please review output or errors file (                                Â
 C:Users76061AppDataLocalTempWB_DESKTOP-UIJ6GDS_123_25300_2_Proje
 ectScratchScrED20file0.err ) for these warning messages.  Â
But when I try to find this error file, the folder " ProjectScratch" can not be found in my computer.
Looking forwards to your reply.
April 20, 2020 at 1:34 am
peteroznewman
SubscriberThese are warnings not errors and can be ignored.
April 20, 2020 at 3:44 am
Aniket Chavan
Forum Moderatoruwindsorspz, In addition to what Peter has told, you can check the file.err file in the solver file directory and open it with notepad. To get to solver file directory, right click on the solution branch of the tree and click "Open Solver File Directory".
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
March 4, 2021 at 3:28 am
uwindsorspz
Subscriber***** FATAL ERROR *****n Call to fAnsMemAlloc with negative length= -935352604n This is probably due to an integer overflow inn the calculation of the block size.n The data type is= 3 and the block name= lsclfac nnnHello, above is the fatal error. Could you help me to figure out what happened about it?n -
January 11, 2023 at 5:39 am
Ashwinkumar Patil
Subscriber ***** FATAL ERROR ***** Call to fAnsMemAlloc with negative length=     -1568559951 This is probably due to an integer overflow in  the calculation of the block size. The data type is=  3 and the block name= modElemMatPertOb A traceback follows: Current ANSYS Traceback:   modElemMatPertObj       Â   crtElemSpaceNewGen       Â   AllocSolutionMemory      Â   slvstr             Â   solvcl             Â   ANSYSÂGetting above fatal error message. Can anybody help
- The topic ‘An error occurred inside the SOLVER module: general error.’ is closed to new replies.
5814
