April 10, 2023 at 7:50 pm
Abdualraouf
SubscriberI am getting this error while i am checking the gab for the contacts, and some contact appear as inactive i don't understand where is the problem is , and the model fail to converge with many warnings.
any help will be very appretiated.
 *** WARNING ***                        CP =     43.594  TIME= 22:45:48
 There are no selected nodes.                                          Â
 Parameter _MINX will be set to 1.2676506E+30.                        Â
 Parameter _MINY will be set to 1.2676506E+30.                        Â
 Parameter _MINZ will be set to 1.2676506E+30.                        Â
 Parameter _MAXX will be set to -1.2676506E+30.                       Â
 Parameter _MAXY will be set to -1.2676506E+30.                       Â
 Parameter _MAXZ will be set to -1.2676506E+30.                       Â
 *** ERROR ***                          CP =     43.672  TIME= 22:45:48
 Node 0 is not defined.                                                Â
 ***** WARNING *****
 Undefined parameter used in field 3 (NX(_NTETS(_I))+_DELTA)
 Line=n,_nspr,nx(_ntets(_i))+_delta,ny(_ntets(_i)),nz(_ntets(_i))
 ***** WARNING *****
 Undefined parameter used in field 4 (NY(_NTETS(_I)))
 ***** WARNING *****
 Undefined parameter used in field 5 (NZ(_NTETS(_I)))
 *** WARNING ***                        CP =     43.672  TIME= 22:45:48
 Undefined parameter used for coordinate 1.                            Â
 A value of 0.0 will be used.                                         Â
 Undefined parameter used for coordinate 2.                            Â
 Undefined parameter used for coordinate 3.                            Â
 A value of 0.0 will be used. -
April 11, 2023 at 5:20 pm
Ashish Khemka
Forum ModeratorHi,
The message 'There are no selected nodes' indicates that there are no nodes selected. Are you using a command object? If yes, then can you please ensure that the nodes are selected?
Ashish Khemka
April 14, 2023 at 10:30 am
Abdualraouf
SubscriberTHANK YOU ASHISH, I AM NOT USING COMMAND OBJECT.Â
when i am trying to evaluate contact tool i am facing troubles with it ''an error occurred inside the POST PROCESSING module'' , after i chaneged the reinforcemnt bar model type from ''reinforcement '' to ''beam'', i got results with contact tool.
its quite complex model though i am searching for a linear results.
- The topic ‘An error occurred inside the POST PROCESSING module’ is closed to new replies.
5849
