May 6, 2024 at 9:51 am
Tim Vic
SubscriberI am trying to perform fatigue analysis of a shaft subjected to torsion and compression load. I can see the total deformation and stress but can't see the results animation for fatigue and stress tools. It shows an error saying "An error occurred in the POST PROCESSING module while reading the result file."
Help
May 7, 2024 at 9:17 am
Sampat Kumar
Ansys EmployeeHi
what type of material you are using? Are the input material data available for this fatigue analysis?Â
Best Regards
Sampat -
May 9, 2024 at 7:01 am
Tim Vic
SubscriberI am using the default structural steel. There is strain life and S-N curve data by default.
- The topic ‘An error occurred in the POST PROCESSING module while reading the result file.’ is closed to new replies.
