April 29, 2024 at 2:46 am
April 29, 2024 at 1:45 pm
Forum ModeratorThat looks like a parallel issue. Restart from the last saved case & data (you did use Autosave?) and see if it's repeatable. PMPI errors can be hardware related as often as Fluent, and may be caused by network traffic and virus scans. If it's repeatable then it's more likely to be Fluent.Â
April 29, 2024 at 1:58 pm
Federico
Ansys EmployeeHello Kim , when does this issue occur? Does your case run for several iterations before the error occurs, as your residuals suggest? Or does it happen on the first time step with Dynamic mesh? -
April 30, 2024 at 9:27 am
kim kyurae
SubscriberThis error occurred during the interpretation of 8 seconds, with approximately 5 seconds or 1300 iterations elapsed. The CPU used is an i9-13900KF, and 14 cores were allocated in the solver settings. The analysis was conducted by opening the saved case file, and using the Report Definitions feature to save around 14 files for each time step.
April 30, 2024 at 12:29 pm
Federico
Ansys EmployeeThen I agree with Rob. Is this error repeatable?
- The topic ‘An error occurred during the analysis of Fluent dynamic mesh’ is closed to new replies.
5674
1890
1419
1304
