March 6, 2019 at 4:15 pm
Zezhao
SubscriberHi, I have tried to do an electromagnetic simulation in Ansys workbench 17.1 after importing the geometry from Solid Edge 2019 via IGS format, and there was an unknown error made it unsuccessful, then I checked the solver output which shows the following information:Â
 *** WARNING ***                        CP =      1.672  TIME= 15:48:46
 The Distributed ANSYS solution does not support SOLID117 elements.    Â
 Distributed parallel processing will be deactivated for this solution.Â
 *** NOTE ***                           CP =      1.703  TIME= 15:48:46
 Distributed parallel processing has been temporarily disabled.        Â
 ***** ANSYS SOLVE   COMMAND *****
 *** TREE GAUGING FOR EDGE ELEMENTS ***
 *** ERROR ***                          CP =      1.766  TIME= 15:48:46
 *** GAUGE command aborted ***                                         Â
 *** NOTE ***                           CP =      1.766  TIME= 15:48:46
 Distributed parallel processing has been reactivated.                 Â
 NUMBER OF WARNING MESSAGES ENCOUNTERED=         1
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=         1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
Can someone helps me to solve this? Many thanks!
March 9, 2019 at 1:48 pm
Zezhao
SubscriberThe problem was solved after I made several different attempts, though I am not sure what exactly solved the problem. I am writing the possible reasons according to my personal experience as an instruction to other people who may face the same problem as mine:
1. Try merging your geometry to one part with separate bodies (use the closure command in Tools)
2. Trying adopting appropriate meshing size
3. Assigning suitable materials to different parts
4. When using 'strand' type of current source, make sure you flux parallel faces (closure faces) contact directly to your current and voltage applying faces
Hope these would be helpful, good luck!Â
March 2, 2020 at 2:30 am
Sam254
SubscriberHi,Â
I had the same problem and the Solution numbered 1Â above worked for me
thanks
May 11, 2020 at 1:41 pm
divyajbhatt
SubscriberHi I am getting this same error while solving.Â
 Distributed parallel processing will be deactivated for this solution. "
Can you help me how to solve it , I have recently started working on ANSYS and i have tried all 4 methods discussed above.Â
Thank you. -
September 22, 2020 at 4:40 am
- The topic ‘An Error Encountered During the Simulation in ANSYS 17.1 workbench’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3892
1414
1241
1118
1015
