May 23, 2022 at 10:32 am
ismailhaouach
SubscriberHi all I am modelling a reinforced concrete frame. I am facing the following error when I try to perform the meshing of concrete using VSWEEP command.
Can anyone tell me how to solve the problem ?
Error:
 An allocation was made with a negative length requested: -515458048  Â
 Filename:..\src\FEM_geoEntity.c Linenum:968. Â
May 23, 2022 at 10:53 am
erik.kostson
Can you attach in your next post the commands that lead to this error (so vsweep command etc).
Also what version are you using>
Erik
- The topic ‘An allocation was made with a negative length requested: -515458048 Filename:..\src\FEM_geoEn’ is closed to new replies.
