May 2, 2024 at 8:32 pm
Abhemanyu Palaniswamy Chandrasekaran
SubscriberHello,
I want to model a semi infinite fluid domain using ambient elements in SALE mesh. I have created a solid set using SET_SOLID_GENERAL and the mesh control points required. While defining the *BOUNDARY_AMBIENT keyword, is it mandatory to input the Load curves for Internal energy and Volume fraction?Â
When the pressure inflow/outflow in the ambient boundaries are unknown, can the LCIDs for internal energy and volume fraction be left blank?
May 3, 2024 at 7:31 pm
Ian Do
Ansys EmployeeHi Abhemanyu,
By default, the space outside the ALE mesh has 0 P definition (a kind of computational vacuum, right?).
Defining  *BOUNDARY_AMBIENT without load curves default it to zero p anyway. I think this is an added complexity with no advantage and would advise against it. It may or may not run, but i wouldn't do it anyway even if it "runs". It is added cost for no gain, and also potentially a source of instability because we are not sure how the code will take it.
Ian DoÂ
May 3, 2024 at 8:33 pm
SubscriberHi Ian,
Thanks for the explanation.
Regards
Abhemanyu
- The topic ‘Ambient Elements in S-ALE’ is closed to new replies.
