TAGGED: aedt, ansys-hfss, ansys-q3d-extractor, Ansys-Siwave, eye-diagram, s-parameter
March 25, 2024 at 3:30 am
Jonghee Park
SubscriberAfter modeling connectors, cables, and PCBs using SI wave, Q2D, and HFSS respectively, I extracted S-parameter data from each simulator and used AEDT to generate an integrated channel's eye diagram. However, when I compared this with the eye diagram extracted from the actual model measured using a network analyzer, I found significant discrepancies. The modeled eye diagram seems to lack consideration for reflections, transmissions, mismatches, etc., making it unrealistic. I'm curious about methods to obtain an eye diagram that closely matches the measured values.
March 25, 2024 at 1:25 pm
Dan Dv
Ansys EmployeeWhen you extracted the various models, were they all at nominal conditions, or are you simulating across manufacturing process corners? Even if you just consider the effects of manufacturing on characteristic impedances, a single eye diagram simulation with all models at their nominal impedance is going to be something of a best case scenario. You may want to consider taking a design of experiments approach where you have multiple versions of each model to account for that process cornering and set up a series of sweeps to include all of the potetnial scenarios.Â
- The topic ‘Aligning Modeled and Measured Eye Diagrams in Channel Analysis’ is closed to new replies.
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
4597
1495
1386
1209
