Optics
Optics
Topics related to Speos.
Airy disk, spot size, Resolution
    • uzmayaqoob1960
      can you plz help to understand these statements
       the spot size depends on the wavelength and F/#W, but the resolution
      depends on the wavelength and entrance pupil diameter
       So a big F/3 lens can resolve finer detail than a small f/3 lens, even though the spot sizes are the same, because the image plane is further away.
      Spot size Diameter (D)2*(1.22*lambda/NA)=2.44*lambda/NA
      How for big lenses image plane is further away?
    • Niki Papachristou
      Hi Uzma,
      Thank you for reaching out to us. I believe what you are describing can be explained by taking into account the definition of F#:
      The f-number is given by:
      F#=f/D
      where f is the focal length, and D is the diameter of the entrance pupil (effective aperture).
      If you want to increase the entrance pupil diameter and keep the same F# then the focal length will lave to be increased, hence the image plane is further away.
      Hope that was helpful.
      Kind Regards,
      Niki
    • uzmayaqoob1960
      Dear Niki
      Thank you for your response . can u plz let me know how further imaging plane ensures better resolution?
    • Niki Papachristou
      Hi Uzma,
      Thank you for coming back. Can I ask you how you ended it up to this conclusion and show me your example of your different lenses with better resolution (some screenshots would be helpful)? I think the reason is simply since you are out of focus furthering your image plane you get better focus and as a consiquence better resolution.
      Kind Regards,
      Niki
    • uzmayaqoob1960
      Dear Niki i have read this concept in one of your paid courses of zeemax.Snapshot is attched herewith.
Viewing 4 reply threads
  • The topic ‘Airy disk, spot size, Resolution’ is closed to new replies.
