March 10, 2024 at 8:12 am
Anunda Chuenlerssakul
SubscriberHi all,
I have try to simulate the motor model with and without mesh in the air gap by using the air material for the meshing and my air gap is 8 mm, I'm wonder why the meshing is of air gap is effect the force result also what does the algorithm of the force and torque calculation?? I know that 3D transient using the virtual work principle but not understand which area is significant in the software calculation?
Thank you,
Anunda
March 13, 2024 at 2:52 pm
MirandaH
Ansys EmployeeHi, the force and torque calculations are performed using the virtual work method. This involves calculating the magnetic energy/coenergy in the simulation, and then evaluating the virtual change in co/energy at the surfaces of the selected objects as if the mesh had moved. Please refer Maxwell Online Helpf for more details.
March 14, 2024 at 6:04 pm
SubscriberThank you for the clarification.
- The topic ‘Air gap meshing in 3D transient’ is closed to new replies.
3777
1388
1188
1090
1015
