June 9, 2020 at 4:27 am
June 9, 2020 at 4:37 am
Charudatta Bandgar
SubscriberHello Biraj Dey ,
Are you facing this issue specific to this project file?Â
You can try deleting the %temp% folder or restarting your computer.
June 9, 2020 at 4:54 am
biraj.dey
SubscriberI am facing this for all project files.
I have tried deleting %temp% folder and restarting now, the issue still remains.
June 9, 2020 at 6:12 am
Charudatta Bandgar
Can you please go to C:Users
AppDataLocal , go to Ansys folder and rename folder "v193" to "v193_old".Restart AIM and let me know if you are still encountering the same issue.
June 9, 2020 at 11:38 am
biraj.dey
SubscriberIt's still the same. It hangs after opening.
June 11, 2020 at 4:03 am
Charudatta Bandgar
Does it take longer to open? If yes, How long do you have to wait before it opens?
Can you try a small simplified model, and replicate the issue you are facing?Â
Can you tell me your system specifications?
June 11, 2020 at 4:31 am
biraj.dey
SubscriberCharudatta Bandgar said:
Does it take longer to open? If yes, How long do you have to wait before it opens?ÂIt doesn't open at all, the screen opens and gets stuck as shown in the image.
Upon minimizing and opening again, it shows blank screen.
 Can you try a small simplified model, and replicate the issue you are facing? ÂYes, I just saved only the geometry without applying any physics or solutions in AIM. Upon opening it, it shows the same problem
 Can you tell me your system specifications?Intel (R) Core (TM) i7-8850H CPU 2.60 GHz
RAM: 32 GB
Core :6
Dedicated GPU memory : 4 GB
June 11, 2020 at 4:45 am
Charudatta Bandgar
Can you uninstall ANSYS and reinstall the setup with 'Run as administrator' ?
I can see that you are using 2019R1, is it possible for you to migrate to the latest version, as this could be a bug that is removed in subsequent versions?
- The topic ‘AIM model does not open after saving it’ is closed to new replies.
5729
