August 7, 2024 at 7:11 am
CAP_NJ
SubscriberDear all,
I am struggeling with the acoustic pressure fluctuation extracted by the FWH acoustic model (Gutin as well as classic FWH). After reaching a statistically steady solution I try to extract the acoustic pressure fluctuation and ahould get a fluctuation around ZERO. This is not the case for my simualtion. What is the problem there? Any ideas? I guess it has something to do with the atmospheric pressure the fwh model uses tio extract the acoustic pressure fluctuation. Is the fwh model uses kind of a averaged pressure of the domain or the reference pressure of the reference values dialog box? Any help is welcome! Thanks in advance!
August 14, 2024 at 1:56 pm
Federico
Ansys EmployeeHello,Â
what are you using as the Reference Acoustic Pressure when setting up FW-H?
August 20, 2024 at 3:57 pm
CAP_NJ
SubscriberSorry to bother you again but I was wondering weather you have any further ideas? Thanks and best regards!
August 14, 2024 at 2:00 pm
CAP_NJ
SubscriberHi Frederico,
thanks for your answer!!! I am using the default 2e-5 Pa (which I gues has something to do with the human hearing limits) reference pressure.
August 15, 2024 at 2:41 pm
CAP_NJ
SubscriberIn the theory guide is the general following definition:
And then after the derivation and some assumptions from the stokes FWH formulation it gives the following relations for the pressure fluctuation p' (T thickness and L loading term):
I dont get where it calculates the average pressure (like in the first relation p_0), which must be subtracted to get a fluctuation around zero???
There was a similiar post, but no answer yet.
https://innovationspace.ansys.com/forum/forums/topic/acoustic-pressure-calculation-les-fh-w/
