April 2, 2026 at 2:53 pm
marcberthoud
SubscriberI'm in AEDT and would like to have a cross section to analyze the fields and see the mesh. Web search indicates I have to select the object I'm interested in then go to ... -> Surface -> Section.. But the sections is NOT AVAILABLE. What is the simplest way to get a cross section to be able to see fields and meshing inside a cube? Screenshot is at
April 2, 2026 at 11:41 pm
Takeshi Itadani
Ansys EmployeeThe easiest method is to use the Clip Plane function.
First, create the plane you want to display the cross-section on by selecting the menu Draw > Plane.
With the plane you just created selected under Planes in the Model tree, select the menu View > Clipping > Add Clip Plane.
In the Clip Plane dialog box, planes with "Enabled" checked will be enabled for cross-section display. Checking "Flip" will reverse the direction of the cross-section.
April 5, 2026 at 6:42 pm
April 6, 2026 at 12:26 am
April 6, 2026 at 2:29 am
marcberthoud
SubscriberThank you, this is very useful and allows me to study the inside of the mesh. Quick followup, is there a simple way to move a cliping plane? The only way I found is to moving the non-model plane and defining a new clipping plane with it.
I also found that the mesh is much coarser than I want it to be as I'm interested in accurate model of the fields. Is there a way to limit the maximum length of any mesh edge?
Thanks
April 6, 2026 at 2:43 am
Takeshi Itadani
Ansys Employee> The only way I found is to moving the non-model plane and defining a new clipping plane with it.ÂYes, please run Clip Plane using that method.ÂÂ> I also found that the mesh is much coarser than I want it to be as I'm interested in accurate model of the fields. Is there a way to limit the maximum length of any mesh edge?ÂTo manually configure meshing, select the object for which you want to generate a finer mesh, and then go to the menu HFSS > Mesh > Assign Mesh Operation.ÂFor dielectrics, you can set the maximum mesh length of the Initial Mesh by selecting Inside Selection > Length Based...ÂFor conductors, you can set the maximum mesh length of the Initial Mesh by selecting On Selection > Length Based...ÂNote that the maximum mesh length set manually is applied during the Initial Mesh process. Further finer meshes may be generated in areas requiring higher precision during subsequent Adaptive analysis.
5969
1307
