TAGGED: cad, link, maxwell-3d, regenerate, spaceclaim, update
February 9, 2024 at 11:20 am
johann.asam
SubscriberHi there,
I have a CAD model created in SpaceClaim that is linked into Maxwell 3D. This is very nice because if I change something on the model, I can easily update it in Maxwell 3D without having to redo all the assignments again. But now I have the problem that if I move the SpaceClaim model to a different location and try to update it in Maxwell (right click -> Generate), Maxwell throws an error message: "Submodel: Unable to open document. Please close all open SpaceClaim sessions and try again".
Is there a way to update the location information of the underlying SpaceClaim model so that I can just update it in Maxwell and don't have to import it again?
February 13, 2024 at 3:03 pm
Jason.k
Ansys EmployeeHello JAs,
I tried to reproduce your issue and I found that the connection between AEDT and SpaceClaim seems to operate appropriately.
The error comes when the SpaceClaim file has changed location while the connection between SpaceClaim and AEDT is considered ActivePlease, make sure that before changing the path (the location) of the SpaceClaim model you have saved the desired changes in SpaceClaim and you have closed the session (the connection) between SpaceClaim and AEDT by closing the AEDT Session. In other words, just make sure that there is no active connection between the models.
After the forced (desired) interruption between the sessions, you will be able to move the SpaceClaim file to an another location. After you do so, open again the AEDT providing a connection in the Active Session. A new connection should be established with no issues.
Kind regards,
Jason.
- The topic ‘AEDT – Maxwell 3D Update Link to SpaceClaim Model’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1338
1188
