July 19, 2024 at 12:45 am
hakjunsimon.lee
SubscriberHi, I'm running a case in AEDT Icepak and is now stuck at "Writing solver input" stage.
I gave it few days to see if there's any progress but none so far. I'm running the case with the setup of two machines, 8 tasks and 64 cores allocated each.
May I have any suggestion on how to move beyond the stage?
Thank you
July 24, 2024 at 1:46 pm
Pdev
Ansys EmployeeHi,Â
Thanks for reaching out. We will need to review your model, hence would recommend filing a ticket. Thanks!
Pdev -
July 30, 2024 at 5:31 am
hakjunsimon.lee
SubscriberÂ
Hi, how do I file a ticket? Also, by any chance are you aware of any general reason for the abrupt termination of solver while running AEDT Icepak once it reaches to ‘Writing Coupling Section Journal file’? The program simply fails to run the solver after the step.
Also experiencing "Com Engine non-responsive" error or "Solver initialization failed". Could there be a sharing factor that causes all the problems?
Thanks for your assistance.Â
- The topic ‘AEDT Icepak stopped running’ is closed to new replies.
5074
1798
1387
1248
