February 3, 2023 at 12:43 pm
Andy Gelin
SubscriberHello,
I would like to know if the ESEL command can use different VMIN condition for different element defined by etable. Or if there is another possible way (instead of using do-loops). I use the following code and it doesnt work.
etable,pl_stn,eppl,eqv
etable,hypress,nl,hpres
etable,el_eqs,s,eqv
sexp,triax,hypress,el_eqs,1,-1
sexp,h1,triax,,-1,1
sadd,crit1,h1,,0.015
esel,s,etab,pl_stn,crit1
esel,r,etab,triax,-1/3,0
Could someone help me with this problem please? Thank you! -
February 6, 2023 at 5:12 am
mrife
Ansys EmployeeHi Andy
Yes different vmin's can be used for different selections. Please describe what you mean be 'doesn't work'. For example there is a big difference between ending up with an empty set to plot, and ending up with the wrong set to plot. That being said using a element table as a vmin amount...well that's a new one on me. I'm not sure that will work as I think you intend. May need to change tactics there. MikeÂ
- The topic ‘ADPL command ESEL -> vmin’ is closed to new replies.
3597
1263
1107
1068
953
