Adjusting vector field visualization
    • justintso1199
      Hi all,
      I was wondering if there was a way to make a vector field in CFD-Post less dense. I like the shape of my ensuing vector field, but my mesh has a lot of elements, so when you're not zooming in super close, you can't really make out the individual vectors because they're so tightly packed. Ideally, I'd like to decrease the density and increase the length of the vectors so that these vectors are more apparent. Thanks for your help.
    • Keyur Kanade
      In details of vector, please select Reduction --> Max number of points.
      By default it is 100. You can reduce it.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘Adjusting vector field visualization’ is closed to new replies.
