Adjoint Energy -error received signal sigsegv
    • arif.coemert
      Hello
      I get the error message (Node 0: Process ....: Received signal SIGSEGV.) when initializing the adjoint solver with adjoint energy. If the adjoint_energy option is disabled or the solid zones are deleted, the adjoint solver starts and converges.
      I want to optimize a heat sink with heat sources, so I need the solid zones in the simulation.
      How can I start Adjoint Solver with adjoint energy and  the solid region ?
      It should work. Did you select wall & shadow for any deformation?
