February 12, 2020 at 6:35 pm
ZengHuang
I am currently doing the Additive Manufacturing Process Simulation. The above image is my impeller at the MAPDL. As I am using the Additive Wizard, it should generate support automatically as I selected create support. But nothing has happen after that step.Â
Unlike what I did to the single blade simulation, I have successfully generate the support with the same step.Â
Can I know why this happen and how to solve this? Thank you!
February 13, 2020 at 10:41 am
Kajal Khan
Ansys EmployeeCan you check it by changing the overhang angle in the wizard?Â
February 16, 2020 at 2:50 pm
ZengHuang
SubscriberYes, I have tested any value between 1 to 90 and it just doesn't work.Â
- The topic ‘Additive Wizard not able to generate support’ is closed to new replies.
1829
1387
1248
