October 6, 2023 at 2:20 am
viv123
SubscriberHello,
I run the analysis for sintering but it shows error to say like the following.
The TB command is not available since Additive Manufacturing (-AMFG)Â Â Â
 was not specified for this Ansys session.  Contact your Ansys support person for more information.Â
We have a licence product 2022 R1. Why Additive suite not working to perform the Sintering Wizard.
Ansys team Please have a look into this issue.
Thank you!
October 6, 2023 at 7:40 am
Akshay Maniyar
Ansys EmployeeHi viv123,
According to the message you shared, it seems your run does not have access to the Ansys Additive Suite license that is required for the type of analysis you are trying to use. Maybe you did not open Mechanical with an Ansys Enterprise level, instead, you used a lower one, which causes Mechanical not to call the Ansys Additive Suite license
Please check the solve.out for the license used when you are running the simulation.
Thanks,
Akshay maniyar
October 6, 2023 at 7:58 am
viv123
SubscriberDear Akshay Ji,
Thank you for your reply, How do i ensure to use mechanical enterprise before running the solution. Please check the attached solve.out file.
Also when i click on model, it shows license prefernce at right side in which i can see the option of enterprise, (should i select this before run). Or is there any way to choose enterprise before runing.
Thank you
October 6, 2023 at 9:04 am
Akshay Maniyar
Please check the first line of the solver output file to check which license is used. To set preferences, you can select enterprise in the option you are seeing in the workbench window. Also, try setting the preferences in mechanical under File < Licensing as shown in the image below.
Thanks,
Akshay Maniyar
October 6, 2023 at 9:28 am
October 9, 2023 at 6:09 am
viv123
SubscriberDear Akshay Maniyar Ji,
I tried bothg the things andd checked the license from the first line of solver output file. It showsÂ
 Ansys Mechanical Enterprise Academic Research  like this.
Aslo setting the license from workbench window and licensing option not solving the problem. It gives same errorÂ
 was not specified for this Ansys session.                             Â
Please update about it.
Thank you!
October 10, 2023 at 5:06 am
viv123
SubscriberHello,
We have a licence product 2022 R1. When we check solver output file it shows " Â Ansys Mechanical Enterprise Academic Research" license.Â
Thank you!
October 11, 2023 at 11:16 pm
John Doyle
Ansys Employee -
October 13, 2023 at 1:34 am
viv123
SubscriberDear John Doyle,
Thank you for your response.
Yes, it worked.
- The topic ‘Additive Suite’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
4387
1494
1375
1203
