February 26, 2025 at 8:00 pm
February 28, 2025 at 2:11 pm
Gary_S
Ansys EmployeeHello
From the Additive Prep User Guide > Licensing....
The Additive Prep application is implemented as a tab in SpaceClaim. You need to have an appropriate license for the Additive tab to appear. Additive Prep is included with Additive Suite and Additive Print licenses. It is also available separately as an add-on to SpaceClaim. See your Ansys Channel Partner to find out about your licensing options.Even if you have a proper license, the Additive Prep application is not enabled by default. To enable the application, in SpaceClaim, click File > SpaceClaim Options > License and then check Additive Prep. Click OK. (If the Additive Prep option appears grayed out, it means you do not have a proper license.) The option is "sticky" in that once you have checked the box, it will remain checked each time you open SpaceClaim, until you clear the box.
March 3, 2025 at 7:58 pm
lcrisostomo9564
SubscriberHi,
Thank you for your response. I checked Additive Prep in th License tab in SpaceClaim but additive prep within the add-ins is still grayed out. If I'm able to check box Additive Prep in License, does that mean we have that license? We also have Additive 2024 R1 downloaded on our school computers.
March 3, 2025 at 8:06 pm
Gary_S
HelloFrom:Â ProductToFeatureMap-2024-10-15OCT2024PDF.pdf
Please check your license keys for these features:Â
Ansys Additive Suite   a_spaceclaim_dirmodÂ
Ansys Additive Suite   am_moduleÂ
Ansys Additive Suite   am_prepÂ
Ansys Additive Suite   am_printÂ
- The topic ‘Additive Prep Inactive’ is closed to new replies.
6875
1343
1152
