February 29, 2024 at 2:16 am
Abraham Martinez
SubscriberHello,
I am currently trying to use MAPDL to run an additive manufacturing simulation. I have a simulation set up in workbench and created the input file from it, then tried to run it in MAPDL and got the error "The AMTYPE command is not available since Additive Manufacturing. (-AMFG) was not specified for this ANSYS session. Contact your ANSYS support person"
On another thread (which has now been closed), an ANSYS employee mentioned that you should be adding "-amfg" as an additional command line argument in the "Solve process settings" window, but I am still running into the same error. I added the command line, re-exported the input file, and opened it with MAPDL. No luck.
Is there something else I should be checking? It seems like MAPDL doesn't know how/when to use the additive license, and I'm not sure how to make it do that.
Thanks in advance.
February 29, 2024 at 2:10 pm
John Doyle
Ansys Employee-
March 6, 2024 at 3:49 am
Abraham Martinez
SubscriberThanks, this did end up working for me.
- The topic ‘Additive Mfg Simulations in MAPDL’ is closed to new replies.
5664
1890
1414
1304
