Photonics
Photonics
Adding transparent conductor oxide
    • ZI YUAN Chang
      Hi, I am trying to add transparent conductor oxide such as aluminium-doped zinc oxide(AZO) as a new material in HEAT. I can't find out the thermal and electronic details for the AZO. what is the other way to construct such a new material? The doping concentration should also be considered as well. What should I do?  Please help!!!
    • Niki Papachristou
      Hi Zi,
      Thank you for reaching out to us. Unfortunately, there is not a workaround rather than finding the thermal and electronic properties and import them into the material explorer.
      Kind Regards,
      Niki
  • The topic ‘Adding transparent conductor oxide’ is closed to new replies.
