August 31, 2022 at 9:49 am
luciano
SubscriberHello!
I would like to know if there is a bug with parameter creation ressource in Discovery 2022 R2 version please. I can set the dimension needed with ruler, but it doesnt work when I try in parameter tab
September 1, 2022 at 2:18 am
Charudatta Bandgar
Subscriber  Hello Luciano França
Let me check this on my end, I will let you know.
Regards.
September 1, 2022 at 6:35 am
luciano
SubscriberCharudatta Bandgar Hi there. Much appreciated!!
September 1, 2022 at 7:15 am
Charudatta Bandgar
SubscriberHello Luciano França
You can create a parameter by using ruler option like this:
What is the other way you are trying to do it as? And what issue are you facing with it?
Are you trying to add it manually from here?
If that is the case, I think this is by design and the previous way is the only way you can parameterize a dimension or property for it to appear here.
Let me know if my understanding of the issue is correct.
Regards.
September 1, 2022 at 9:04 am
luciano
SubscriberCharudatta Bandgar Thank you for the explanation!! I think something went wrong with my geometry (I used ruler option) and I just repaired it.
- The topic ‘Adding parameters’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4597
1495
1386
1209
