Adding multiple load cases in one mechanical model for static structure
    • Sufiyan
      I have a modelling project, wherein i need to compare my experimental data to the modelled data from ansys and thereafter optimise the model.nI need to model 6 kinds of loading, i.e. torsion, bending, axial and shear for my model. I have different boundary conditions and load applied for all 6 different load types. Hence its a static model for all and only loading and boundary condition is changing for each load type.nI would like to know if there is an easy way where i can keep a track of all 6 types of load under one model please. n
      In Workbench, the first Static Structural block, the Model cell A4 is where the meshing and material assignment is done, then drag and drop multiple Static Structural blocks onto the Model cell A4, B4, C4 for each additional load case.nIn Workbench, you can drag and drop the Fixed Support from the first analysis onto each additional analysis. Then each analysis can have its own unique force.nn
    • Alexander Nadareyshvili
      It's very handy. But, how I can write dat file with multiple solutions (load cases) to run it on HPC When I selected the multiple solutions, dat file includes no loads.
  • The topic ‘Adding multiple load cases in one mechanical model for static structure’ is closed to new replies.
