Adding moving probes on a zone with mesh motion
    • m.kusbeci
      My problem is about extracting probe data from a moving mesh zone. The geometry I have is of a gas turbine pre-swirl cavity where there is relative motion of receiver holes on rotor and the pre-swirl holes on the stator. The computational domain consists of stationary and rotating zones. I have defined mesh motion on the rotating frame  (rotational).
      In Fluent, is it possible to add a probe in the rotating frame so that the probe travels with the rotating disc? I have tried this without any success in the past; the probes (points) I place seem to stay in the stationary frame. Maybe if there is a way to assign the probe to a specific node location, this could be possible.
      My temporary workaround this problem involves exporting the solution data in each time step in tecplot format, and then read it using paraview. I have written a bash script which updates the probe location for each tecplot file and passes it to the pvpython script, which gives a .CSV file as an output. I then use another python script to combine all the .CSV files from all time-steps into one big .CSV file which contains all the time-steps.
      A simpler approach will be greatly appreciated.
      Kind Regards,
      Maz
    • teoman
      Hi Maz
      Have you found any solution to the your problem that I have the same.
      Regards
      Teoman
      Not at present. The usual trick is to split a cell or facet out of the mesh and monitor that. It's on the "to do" list but not as simple a task as it sounds.
    • teoman
      Dear Rob
      If we can describe Probe wit a Node ID. It may be the solution. Because we can move the Node with CG_Motion or Grid_Motion.And Define Report for Point surfaces.
      I need to track certain nodes on a blade section to verfy the simulation .Because my study is based on a actual experiment results.
      If you can give more info about the trick is to split a cell or facet out of the mesh and monitor that. It would be priceless help for me.
      Many thanks and Regards.
      Teoman
    • teoman
      Hi
      My solution is :
      I defined mini surface areas to represent sensors on a blade section. These areas had different Named Sections and face meshing.
      Assigned the same UDF , which assigned to the blade , to the sensor areas. .So that ,It became possible to define Report on the sensor areas
      with Area Average/ Static Pressiure option.
      Finally I obtained moving and result reporting surface areas for each Time Step.
      Kind Regards.
Viewing 4 reply threads
  • The topic ‘Adding moving probes on a zone with mesh motion’ is closed to new replies.
