October 24, 2023 at 1:02 pm
Khandaker Lubaba Bashar
SubscriberHello everyone,
May I know how to ask the support team to add any components to the Ansys sherlock library?
Please help me.
October 30, 2023 at 1:00 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps you: Parts List — Lesson 8 - ANSYS Innovation Courses
Ashish Khemka
October 31, 2023 at 11:05 am
SubscriberThank you so much Ashish for this link. Actually, I was trying to add the GaN systems' GS66516T GaN devices but failed to add the Gallium Nitride material as die materials. Could you please help me with any email ID that I could use to send the component details to the Sherlock Librarian to request them to add these GaN packages?
November 1, 2023 at 1:23 pm
Ashish Khemka
Forum ModeratorHi,
Please wait for forum members to comment.
Ashish Khemka
November 1, 2023 at 3:41 pm
Gil Sharon
Ansys EmployeeHello Khandaker,
Thank you for the question.
- Add the GaN material to the Library in Sherlock.Â
- Libraries>Materials
- Right click>Add Material
- Make sure to check "DIE" in useage
November 2, 2023 at 10:56 am
SubscriberThank you all for your comments. Hello gsharon, yes I tried this but I was confused about the Material class as there are only 3 options availabe for it, alloy, ceramic and polymer. Would you please help me to select one option among these three for Gallium nitride?
- The topic ‘Adding components to Sherlock Library’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4052
1482
