Electronics
Electronics
Adding a 3D connector to PCB trace in HFSS 3D layout
    • Mohan
      I need some input regarding the vendor 3D connector(SMA, SMD), importing and including it in the RF PCB simulation. If it is explained with a single RF trace, it will be useful.
      Note: The PCB is designed in the Cadence software.
    • Praneeth
      Hi Mohan,
      Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
      Are yout still looking how to insert HFSS 3D component into HFSS 3D Layout?
      If so, please go through this crosstalk on HFSS 3D components 3D Component Creation- Ansys Crosstalk Duplicate | Ansys Innovation Space. It is recommended to go through the full crosstalk as it covers many important points regarding 3D components in Ansys HFSS. Insertion of a 3D component into HFSS 3D layout is covered at the end.
      Best regards,
      Praneeth,
      Click here to join Electronics Community and build a network
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
