October 12, 2023 at 6:31 pm
javat33489
SubscriberHi all.
Does CONTACT_ADD_WEAR work on a rigid body? Is it possible to check the wear on the contact using this contact? For example, if there is a drilling simulation and the drill is a rigid body work on a rigid body? Is it possible to check the wear on the contact using this contact? For example, if there is a drilling simulation and the drill is a rigid body.
Thank you.
October 16, 2023 at 6:37 am
Ushnish Basu
Ansys EmployeeCONTACT_ADD_WEAR is either for post-processing of wear, or for perturbing the surface mesh, so I don't think there should be any restrictions for rigid material, bout you will have to try it out.Â
- The topic ‘CONTACT_ADD_WEAR for rigid body’ is closed to new replies.
1890
1419
1304
